maurizio53
(Maurizio Fabiani)
April 7, 2018, 10:31am
1
I am using nmap to track family devices in this way:
- platform: nmap_tracker
hosts:
- 192.168.1.X
- 192.168.1.XX
scan_options: " --privileged -sP "
interval_seconds: 45
home_interval: 10
new_device_defaults:
track_new_devices: no
hide_if_away: True
but too many times i see my state not at home for few minutes or seconds without moving from my home
as you can see in this shot:
Where is my fault? Is there a better way to track devices?
taikapanu
(Juha Panu)
April 7, 2018, 11:15am
2
Some phones e.g. iPhone drop from WLAN to save battery. You could try to set consider home setting. See more explation here:
maurizio53
(Maurizio Fabiani)
April 7, 2018, 11:18am
3
Thanks, so how to set consider_home in .yaml file?
taikapanu
(Juha Panu)
April 7, 2018, 11:43am
4
Like this. I copied your code from above.
hosts:
- 192.168.1.X
- 192.168.1.XX
home_interval: 10
consider_home: '00:03:00'
hide_if_away: True
You could add a second device tracker component to make your setup more robust (e.g. GPSlogger or Owntracks for GPS or the Bluetooth tracker).
By grouping the different trackers together (not in the known_devices file!), if one device is home the device group is considered home. Only if both devices are “away” the group is marked as “away”.
