Tracking down a rogue light
i have a light that just seemingly randomly turns on and I cant seem to track down where the command to turn it on comes from.
Im controlling all my automations from node red, so when ever something is commanded from there, it shows up in the history as “Turned off triggered by service light.turn_off”.
However I also have some entries that are just “Turned on”
Like in this example. The lights gets turned off by a simple door sensor but then after 20ish minutes it just turns on.
Also if I have the light on dimmed it goes full brightness.
what could be causing this? and is there another way to check where a command is coming from?
