Not a programmer so no idea what is wrong. Any suggestions
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/__init__.py", line 155, in async_setup_platform
disc_info)
File "/usr/lib/python3.6/asyncio/futures.py", line 331, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.6/asyncio/tasks.py", line 244, in _wakeup
future.result()
File "/usr/lib/python3.6/asyncio/futures.py", line 244, in result
raise self._exception
File "/usr/lib/python3.6/concurrent/futures/thread.py", line 55, in run
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/trackr.py", line 29, in setup_scanner
TrackRDeviceScanner(hass, config, see)
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/trackr.py", line 44, in __init__
self._update_info()
File "/usr/lib/python3.6/site-packages/homeassistant/components/device_tracker/trackr.py", line 62, in _update_info
dev_id = slugify(trackr.name())
File "/usr/lib/python3.6/site-packages/homeassistant/util/__init__.py", line 42, in slugify
text = normalize('NFKD', text)
TypeError: normalize() argument 2 must be str, not None
Yeah but it didn’t pick it up. I have actually removed it from my config - wasn’t reliable enough and didn’t like leaving the app running in the background of my iPhone
I only have one, and I use it to track my dog to know if she is home or at my grandmother’s (she watches her during the day) I have an old android phone at her house and my phone on me.
With this setup things have been working reliably. I think the biggest problem is if Bluetooth doesn’t separate from the device, for example you have a trackr with you to track you at all times. Their app doesn’t report you location change often enough. However if you do what I am doing and Bluetooth isn’t always seeing the device it seems to work well.
