Tradfri blinds - working week and weekend automation
Hi guys,
I have recently started to play with Home assistant [installed HASSIO OS on a raspberry pi 4], so basically I am a newbie in all this. May I kindly ask for your help with an automation I built for Ikea Tradfri blinds [onlyone at this point, just to see how it works].
What I tried to achieve is/was:
to split the week days in working days and weekend
to have a specific time when the blinds go up / down
to have the least number of automations [ I end up with two ]
Note: I used - service: cover.set_cover_position instead of cover.close/open_cover because when it was opening, was opening full [regardless of the fact that I set the open value in the gateway]
Question 1 > is there any other way to define when the blind should close, instead of using the ‘delay’ or the ‘sun’?
Question 2 > is there any better way to to built it to end up with only one automation?
- id: '1594654875713'
  alias: Blinds-Weekend
  description: ''
  - at: 08:30
    platform: time
  condition:
  - condition: state
    entity_id: binary_sensor.workday_sensor
    state: 'off'
      entity_id: cover.tradfri_blind
      position: 80
  - delay: '12:30:00'
      position: 0
- id: '1594828467878'
  alias: Blinds-Week
  description: ''
  - at: 06:45
    platform: time
  condition:
  - condition: state
    state: 'on'
  - data:
      position: 80
  - delay: '14:00:00'
  - data:
      position: 0
This text will be hidden
[I hope that I found the proper formatting for the config ]
Thank you
mema
Just as an update > it doesnt fully work. The blinds are opening in the morning and set to configured position, but after that, in the evening, they are not closing
MM
