Tradfri bulb appearing as sensor
Hi, I added a new tradfri bulb to my system yesterday. I put it in a group with only one remote and this bulb.
In Hass.io the bulb appears as a sensor, and the group appears as a light.
Why is that, and can I change this somehow? My other Tradfri bulbs is registered with Hass.io as lights.
Thanks :slight_smile:
Iā€™m having the same issue. I was able to correct the problem by using the iOS app to remove the light from the gateway, then used the iOS app and the remote to add it back in to the gateway (rather than just using the remote by itself). after restarting hass it appeared properly.
Let me know how it works out!
Cheers
Thanks, that solved it.
