Hello!
Long time Homeassistant user… Also been using Tradfri with hass for 8months now, but i recently upgraded my ubuntu 16.04 to 17.10 and reinstalled everything. All works, exepct tradfri configurator wont accept the security key…
I tried factory reseting and rebooting the gateway…
LOG:
2018-04-17 23:21:38 ERROR (MainThread) [homeassistant.core] Error executing service <ServiceCall configurator.configure: configure_id=ID, fields=security_code=KEY>
File “/home/falkaub/.local/lib/python3.6/site-packages/homeassistant/core.py”, line 1002, in _event_to_service_call
await service_handler.func(service_call)
File “/home/falkaub/.local/lib/python3.6/site-packages/homeassistant/components/configurator.py”, line 224, in async_handle_service_call
call.data.get(ATTR_FIELDS, {}))
File “/home/falkaub/.local/lib/python3.6/site-packages/homeassistant/components/tradfri.py”, line 68, in configuration_callback
key = await api_factory.generate_psk(security_code)
File “/usr/local/lib/python3.6/dist-packages/pytradfri/api/aiocoap_api.py”, line 196, in generate_psk
self._psk = yield from self.request(command)
File “/usr/local/lib/python3.6/dist-packages/pytradfri/api/aiocoap_api.py”, line 152, in request
result = yield from self._execute(api_commands)
File “/usr/local/lib/python3.6/dist-packages/pytradfri/api/aiocoap_api.py”, line 142, in _execute
_, res = yield from self._get_response(msg)
File “/usr/local/lib/python3.6/dist-packages/pytradfri/api/aiocoap_api.py”, line 92, in _get_response
r = yield from pr.response
File “/usr/local/lib/python3.6/dist-packages/aiocoap/protocol.py”, line 814, in _run_outer
yield from cls._run(app_request, response, weak_observation, protocol, log, exchange_monitor_factory)
File “/usr/local/lib/python3.6/dist-packages/aiocoap/protocol.py”, line 863, in _run
blockresponse = yield from blockrequest.response
File “/usr/local/lib/python3.6/dist-packages/aiocoap/protocol.py”, line 693, in _init_phase2
yield from self.protocol.fill_remote(self.app_request)
File “/usr/local/lib/python3.6/dist-packages/aiocoap/protocol.py”, line 426, in fill_remote
raise RuntimeError(“No transport could route message”)
RuntimeError: No transport could route message
