I’m trying to get HASS working with a second Tradfri gateway (they are in different locations). It seems that the gateway is discovered on connected, but I can’t see any lights connected to this gateway.
Is this a limitation of the Tradfri component? Any chance this can be fixed?
I also see this in the log file:
Oct 15 10:38:15 nuc-ha hass[8169]: Traceback (most recent call last):
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/lib/python3.5/asyncio/tasks.py”, line 241, in _step
Oct 15 10:38:15 nuc-ha hass[8169]: result = coro.throw(exc)
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/tradfri.py”, line 92, in gateway_discovered
Oct 15 10:38:15 nuc-ha hass[8169]: keys = yield from hass.async_add_job(_read_config, hass)
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/lib/python3.5/asyncio/futures.py”, line 361, in iter
Oct 15 10:38:15 nuc-ha hass[8169]: yield self # This tells Task to wait for completion.
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/lib/python3.5/asyncio/tasks.py”, line 296, in _wakeup
Oct 15 10:38:15 nuc-ha hass[8169]: future.result()
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/lib/python3.5/asyncio/futures.py”, line 274, in result
Oct 15 10:38:15 nuc-ha hass[8169]: raise self._exception
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/lib/python3.5/concurrent/futures/thread.py”, line 55, in run
Oct 15 10:38:15 nuc-ha hass[8169]: result = self.fn(*self.args, **self.kwargs)
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/local/lib/python3.5/dist-packages/homeassistant/components/tradfri.py”, line 152, in _read_config
Oct 15 10:38:15 nuc-ha hass[8169]: return json.loads(f_handle.read() or ‘{}’)
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/lib/python3.5/json/init.py”, line 319, in loads
Oct 15 10:38:15 nuc-ha hass[8169]: return _default_decoder.decode(s)
Oct 15 10:38:15 nuc-ha hass[8169]: File “/usr/lib/python3.5/json/decoder.py”, line 342, in decode
Oct 15 10:38:15 nuc-ha hass[8169]: raise JSONDecodeError(“Extra data”, s, end)
Oct 15 10:38:15 nuc-ha hass[8169]: json.decoder.JSONDecodeError: Extra data: line 2 column 1 (char 47)
Oct 15 10:38:15 nuc-ha hass[8169]: 2017-10-15 10:38:15 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
