Tradfri outlets
Hi
I have two new Tradfri outlets which I added via the Ikea Home Smart app. They then appeared in Home Assistant. However, the two devices appear different in the entities, as shown in the screenshots.
Why is it that the first outlet have a (battery ?) sensor when the other doesn’t ?
I cannot remove this from entities.
I have a few powered devices that provide battery sensors, despite not having a battery. If you go into the device and from there select “Settings > Advanced settings”, you can change the entity to disabled.
Thanks. I’ll do that.
