Did anyone experience high battery consumption of the TRÅDFRI remote control (the round one with 5 buttons)?
I use a Nortek USB stick (Zigbee and Z-Wave) and ZHA. After I updated the stick’s Zigbee firmware to fix my TRÅDFRI Shortcut Button behaviour (it was dropping from the network but was still working when I clicked it), my TRÅDFRI remote control started going through batteries as they were candy (they are lasting just one week)
@zoogara, could you please check the firmware version you are using? I keep OTA updates for Ikea always on for ZHA, so I don’t know if the last drop was caused by a firmware update.
Thanks for checking I will try the traditional solution: Delete the device from HA again and pair it once more while standing in the same spot it will be installed on the wall.
Something made the controller unhappy, maybe the second time’s a charm…lol
Hi did you ever get this sorted. I’m using ZHA with a Sonoff Zigbee 3.0 USB Dongle Plus and have the same firmware version on my TRÅDFRI Shortcut buttons. They drain a battery in about 12 hours!
i think there are some “confusion” in regards to the software-versions above, and in general, on ikeas 5-button remotes. Also there is no mention of whether they are “controlling” lights through the Ikea-Driver or not
Anyway above mentioned firmware is “OLD” , in 2022 they released a firmware to address the battery draining( which helped the most people ) thou obviously if some don’t use the ikea-update, or follow-up on firmware-updates, they don’t get it
It is not worth to say that I had it working fine on firmware 0x23080631, with Sonoff stick using the CC1352/CC2652, Z-Stack 3.30+ (build 20220219) firmware.
