TRÅDFRI Wireless 5-Button Remote double press
Hi using the blueprint from epmatt,
Im having trouble with the double and longpress options.
Single press controls a switch, works fine.
I want a double/ long press to toggle a DIFFERENT switch, without impacting the first switch.
Ive played with the debounce etc, enabled the toggle for double press.
Any ideas? TIA
Have you applied the fix for the double press as discussed in the thread for the blueprint:
Thanks,
Ill try this, thanks for the find
Worked for ZHA.
