Hi guys! I was able following the https://www.smarthomebeginner.com guide to setup Traefik on my domain and I can access Traefik and pi hole from the outside!
But unfortunately I can’t forward HA to Traefik, I’m using the network_mode host and I’m trying to use the backends and frontends but I can’t in anyway see my “custom configuration” to Traefik web interface.
Here’s my Docker-compose
version: '3'
services:
traefik:
hostname: traefik
image: traefik:v1.7.16
container_name: traefik
restart: always
domainname: ${DOMAINNAME}
networks:
- default
- traefik_proxy
ports:
- "80:80"
- "443:443"
# - "8000:8080"
environment:
- CF_API_EMAIL=${CLOUDFLARE_EMAIL}
- CF_API_KEY=${CLOUDFLARE_API_KEY}
labels:
- "traefik.enable=true"
- "traefik.backend=traefik"
- "traefik.frontend.rule=Host:traefik.${DOMAINNAME}"
# - "traefik.frontend.rule=Host:${DOMAINNAME}; PathPrefixStrip: /traefik"
- "traefik.port=8080"
- "traefik.docker.network=traefik_proxy"
- "traefik.frontend.headers.SSLRedirect=true"
- "traefik.frontend.headers.STSSeconds=315360000"
- "traefik.frontend.headers.browserXSSFilter=true"
- "traefik.frontend.headers.contentTypeNosniff=true"
- "traefik.frontend.headers.forceSTSHeader=true"
- "traefik.frontend.headers.SSLHost=example.com"
- "traefik.frontend.headers.STSIncludeSubdomains=true"
- "traefik.frontend.headers.STSPreload=true"
- "traefik.frontend.headers.frameDeny=true"
- "traefik.frontend.auth.basic.users=${HTTP_USERNAME}:${HTTP_PASSWORD}"
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
- ${USERDIR}/traefik:/etc/traefik
- ${USERDIR}/shared:/shared
homeassistant:
container_name: homeassistant
restart: always
image: homeassistant/home-assistant
volumes:
- /home/giacomo/dont:/config
- /etc/localtime:/etc/localtime:ro
privileged: true
environment:
- PUID=${PUID}
- PGID=${PGID}
- TZ=${TZ}
network_mode: host
pihole:
container_name: pihole
domainname: docker
hostname: pihole
image: pihole/pihole:latest
ports:
- '53:53/tcp'
- '53:53/udp'
# - '67:67/udp'
- '8182:80'
- '8183:443'
restart: unless-stopped
volumes:
- ${USERDIR}/pihole/pihole:/etc/pihole
- ${USERDIR}/pihole/pihole.log:/var/log/pihole.log
- ${USERDIR}/pihole/dnsmasq.d:/etc/dnsmasq.d
environment:
- ServerIP=192.168.1.159
- PROXY_LOCATION=pihole
- VIRTUAL_HOST=pihole.${DOMAINNAME}
- VIRTUAL_PORT=80
- TZ=${TZ}
- WEBPASSWORD=PASSWORD
- DNS1=1.0.0.1
- DNS2=1.1.1.1
labels:
- "traefik.backend=pihole"
- "traefik.port=80"
- "traefik.frontend.rule=HostRegexp:pihole.${DOMAINNAME},{catchall:.*}"
- "traefik.frontend.priority=1"
- traefik.frontend.headers.SSLRedirect=true
- traefik.frontend.headers.STSSeconds=315360000
- traefik.frontend.headers.browserXSSFilter=true
- traefik.frontend.headers.contentTypeNosniff=true
- traefik.frontend.headers.forceSTSHeader=true
- traefik.frontend.headers.SSLHost=${DOMAINNAME}
- traefik.frontend.headers.STSIncludeSubdomains=true
- traefik.frontend.headers.STSPreload=true
- traefik.frontend.headers.frameDeny=true
networks:
traefik_proxy:
external:
default:
driver: bridge
Here’s my Traefik.toml
logLevel = "DEBUG" #DEBUG, INFO, WARN, ERROR, FATAL, PANIC
defaultEntryPoints = ["http", "https"]
InsecureSkipVerify=true
# WEB interface of Traefik - it will show web page with overview of frontend and backend configurations
[api]
entryPoint = "traefik"
dashboard = true
address = ":8080"
# Force HTTPS
[entryPoints]
[entryPoints.http]
address = ":80"
[entryPoints.http.redirect]
entryPoint = "https"
[entryPoints.https]
address = ":443"
[entryPoints.https.tls]
[traefikLog]
filePath="/etc/traefik/traefik.log"
[file]
watch = true
filename = "/etc/traefik/rules.toml"
# Let's encrypt configuration
[acme]
email = "EMAIL" #any email id will work
storage="/etc/traefik/acme/acme.json"
acmeLogging=true
onDemand = false #create certificate when container is created
[acme.dnsChallenge]
provider = "cloudflare"
delayBeforeCheck = 300
[[acme.domains]]
main = "DOMAIN.tk"
[[acme.domains]]
main = "*. DOMAIN.tk"
# Connection to docker host system (docker.sock)
[docker]
endpoint = "unix:///var/run/docker.sock"
domain = "DOMAIN.tk"
watch = true
# This will hide all docker containers that don't have explicitly
# set label to "enable"
exposedbydefault = false
And finally my rules.toml
[backends]
[backends.backend-pihole]
[backends.backend-pihole.servers]
[backends.backend-pihole.servers.server-pihole-ext]
url = "http://192.168.1.159:8123"
weight = 0
[frontends]
[frontends.frontend-pihole]
backend = "backend-pihole"
passHostHeader = true
# basicAuth = [
# HTTP Authentication
# "xxx:yyyyyyyyyyyy",
[frontends.frontend-pihole.routes]
[frontends.frontend-pihole.routes.route-pihole-ext]
rule = "Host:DOMAIN.tk"
Could someone please help me?? I’m becoming crazy
