dekela
(Dekel Amrani)
January 17, 2024, 8:40pm
1
I am trying to migrate from ngnix reverse proxy to traefik.
My HA is on a raspberry pi and traaefik is running as a docker container on a different machine (Using Unraid) . I configured external routing in traefik and I am getting Bad Request.
Looking at HA log I see tthe following:
Invalid IP address in X-Forwarded-For: , 85.65.x.x
I have configured:
http:
use_x_forwarded_for: true
trusted_proxies:
Does anyone run the same setup and can help me?
Dekel
_dev_null
(/dev /null)
January 17, 2024, 10:31pm
2
This doesn’t look good at all, normally the x-forwarded-for header contains a , separated list of proxies you have been through so it looks like the header hasn’t been sanitised correctly
dekela
(Dekel Amrani)
January 18, 2024, 4:36pm
3
Agree, I think II even found a bug for something similar:
opened 12:58PM - 04 Jan 24 UTC
### The problem
My installation is fronted by a reverse proxy (traefik) that is… further proxied by Cloudflare, with the usual
http:
trusted_proxies:
- 192.168.xx.yy/24
The HTTP request headers arriving at the Home Assistant are
Cf-Connecting-Ip: MY-CLIENT-IP
X-Forwarded-For: MY-CLIENT-IP, CLOUDFLARE-IP
X-Real-Ip: MY-CLIENT-IP
If I try to log with invalid credentials, the log however contains
2024-01-04 12:18:55.919 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from CLOUDFLARE-IP (CLOUDFLARE-IP)
meaning that while the `X-Forwarded-For` header is trusted, the incorrect component of it is taken.
The `X-Forwarded-For` header has no formal specification and Home Assistant is by far not the only software that gets it wrong; the commonly used definition however does allow for a list and sorts the addresses real-client-first (see e.g. https://developer.mozilla.org/en-US/docs/Web/HTTP/Headers/X-Forwarded-For ).
Proposal:
- either parse and use the first address of the list
- or - better - allow to define the trusted header name itself, instead of a boolean `use_x_forwarded_for`. I am imagining something like `real_ip_from: X-Real-Ip`.
### What version of Home Assistant Core has the issue?
core-2023.12.4
### What was the last working version of Home Assistant Core?
_No response_
### What type of installation are you running?
Home Assistant Container
### Integration causing the issue
_No response_
### Link to integration documentation on our website
_No response_
### Diagnostics information
_No response_
### Example YAML snippet
_No response_
### Anything in the logs that might be useful for us?
_No response_
### Additional information
_No response_
dekela
(Dekel Amrani)
January 18, 2024, 4:38pm
4
Maybe I can run TCP dump on HA to see the request headers.
_dev_null
(/dev /null)
January 18, 2024, 5:18pm
5
Do it, I personally think the header is mangled prior to reaching HA
Or can you point traefik to a web page that simply dumps all the request headers or even simpler run an echo server on port 2500
while true ; do nc -l -p 2500 ; done
dekela
(Dekel Amrani)
January 22, 2024, 6:26am
6
~ # while true ; do nc -l -p 2500 ; done
GET /lovelace HTTP/1.1
Host: 192.168.x.x:2500
User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
Accept-Encoding: gzip, deflate, br
Accept-Language: en-US,en;q=0.9
Cache-Control: max-age=0
Referer: https://host.domain/lovelace
Sec-Ch-Ua: "Not_A Brand";v="8", "Chromium";v="120", "Google Chrome";v="120"
Sec-Ch-Ua-Mobile: ?0
Sec-Ch-Ua-Platform: "Windows"
Sec-Fetch-Dest: empty
Sec-Fetch-Mode: navigate
Sec-Fetch-Site: same-origin
Upgrade-Insecure-Requests: 1
X-Forwarded-Host: 192.168.x.x
X-Forwarded-Port: 443
X-Forwarded-Proto: https
X-Forwarded-Server: 6342128c49cf
X-Real-Ip:
Take a look at the X-Forwarded-For:
I think there’s a bug in Traefik request headers which adds “,”
This is from a ngnix reverse proxy:
GET / HTTP/1.1
Host: host.domain
X-Forwarded-Scheme: https
X-Forwarded-For: 85.65.x.x
X-Real-IP: 85.65.x.x
sec-ch-ua: "Not_A Brand";v="8", "Chromium";v="120", "Google Chrome";v="120"
accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.7
sec-ch-ua-mobile: ?0
upgrade-insecure-requests: 1
user-agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36
sec-ch-ua-platform: "Windows"
sec-fetch-site: same-origin
sec-fetch-mode: navigate
sec-fetch-dest: empty
accept-encoding: gzip, deflate, br
accept-language: en-US,en;q=0.9
_dev_null
(/dev /null)
January 22, 2024, 7:51am
7
Yup
Use a different proxy if you can
SkyHawkNW
(Sky Hawk)
February 8, 2025, 6:02am
8
I had this exact same issue with the comma being added to the header.
ERROR (MainThread) [homeassistant.components.http.forwarded] Invalid IP address in X-Forwarded-For: , 192.168.X.XXX
After hours of troubleshooting I found the issue. I had a traefik plugin to get the real IP from clooudflares proxy (there are a few but the one I was using specifically was soulbalz/traefik-real-ip. Disabling this plugin solved this issue.
Posting this here for any other poor soul who runs in to the same issue
