When searching for “Trafikverket” in the logfile I find the following 7 items:
When clicking on the redmarked ERROR I find the following:
Logger: aiohttp.server
Source: components/trafikverket_weatherstation/config_flow.py:34
First occurred: 13:39:44 (1 occurrences)
Last logged: 13:39:44
Error handling request
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 181, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 157, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 252, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 325, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/components/trafikverket_weatherstation/config_flow.py", line 58, in async_step_user
validate = await self.validate_input(api_key, station)
File "/usr/src/homeassistant/homeassistant/components/trafikverket_weatherstation/config_flow.py", line 34, in validate_input
await weather_api.async_get_weather(station)
File "/usr/local/lib/python3.9/site-packages/pytrafikverket/trafikverket_weather.py", line 85, in async_get_weather
weather_stations = await self._api.async_make_request(
File "/usr/local/lib/python3.9/site-packages/pytrafikverket/trafikverket.py", line 162, in async_make_request
error_nodes = etree.fromstring(content).xpath("/RESPONSE/RESULT/ERROR")
File "src/lxml/etree.pyx", line 3252, in lxml.etree.fromstring
File "src/lxml/parser.pxi", line 1912, in lxml.etree._parseMemoryDocument
File "src/lxml/parser.pxi", line 1793, in lxml.etree._parseDoc
File "src/lxml/parser.pxi", line 1082, in lxml.etree._BaseParser._parseUnicodeDoc
File "src/lxml/parser.pxi", line 615, in lxml.etree._ParserContext._handleParseResultDoc
File "src/lxml/parser.pxi", line 725, in lxml.etree._handleParseResult
File "src/lxml/parser.pxi", line 654, in lxml.etree._raiseParseError
File "<string>", line 1
lxml.etree.XMLSyntaxError: Start tag expected, '<' not found, line 1, column 1
And the other hits, below:
Unfortunatly I can not interprete what the issue is and where to search next.
I would appriciate any inputs/ideas.
BR Christian
