I am running this on Synology + Docker + z-wave USB stick.
The current sensor temperature is reporting properly, I can turn the heat on and off. When I change the temp set point it does not work.
Here are the OZW logs when I toggle heat on and off which is working:
2017-10-19 14:48:34.789 Info, Node007, Value::Set - COMMAND_CLASS_THERMOSTAT_MODE - Mode - 0 - 1 - Off
2017-10-19 14:48:34.790 Detail, Node007, Queuing (Send) ThermostatModeCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x40, 0x01, 0x00, 0x25, 0x42, 0xc4
2017-10-19 14:48:34.790 Detail, Node007, Queuing (Send) ThermostatModeCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x40, 0x02, 0x25, 0x43, 0xc4
2017-10-19 14:48:34.791 Info, Node007, Sending (Send) message (Callback ID=0x42, Expected Reply=0x13) - ThermostatModeCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x40, 0x01, 0x00, 0x25, 0x42, 0xc4
2017-10-19 14:48:34.798 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-10-19 14:48:34.798 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2017-10-19 14:48:34.815 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0x42, 0x00, 0x00, 0x03, 0xaa
2017-10-19 14:48:34.816 Detail, Node007, ZW_SEND_DATA Request with callback ID 0x42 received (expected 0x42)
2017-10-19 14:48:34.816 Info, Node007, Request RTT 24 Average Request RTT 24
2017-10-19 14:48:34.816 Detail, Expected callbackId was received
2017-10-19 14:48:34.816 Detail, Expected reply was received
2017-10-19 14:48:34.816 Detail, Message transaction complete
2017-10-19 14:48:34.816 Detail, Node007, Removing current message
2017-10-19 14:48:34.816 Info, Node007, Sending (Send) message (Callback ID=0x43, Expected Reply=0x04) - ThermostatModeCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x40, 0x02, 0x25, 0x43, 0xc4
2017-10-19 14:48:34.823 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-10-19 14:48:34.832 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2017-10-19 14:48:34.840 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0x43, 0x00, 0x00, 0x02, 0xaa
2017-10-19 14:48:34.840 Detail, Node007, ZW_SEND_DATA Request with callback ID 0x43 received (expected 0x43)
2017-10-19 14:48:34.841 Info, Node007, Request RTT 24 Average Request RTT 24
2017-10-19 14:48:34.841 Detail, Expected callbackId was received
2017-10-19 14:48:36.351 Detail, Node007, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x40, 0x03, 0x00, 0xb5
2017-10-19 14:48:36.352 Detail,
2017-10-19 14:48:36.352 Info, Node007, Response RTT 1536 Average Response RTT 1497
2017-10-19 14:48:36.352 Detail, Node007, Refreshed Value: old value=1, new value=0, type=list
2017-10-19 14:48:36.352 Detail, Node007, Changes to this value are not verified
2017-10-19 14:48:36.352 Info, Node007, Received thermostat mode: Off
2017-10-19 14:48:36.352 Detail, Node007, Expected reply and command class was received
2017-10-19 14:48:36.352 Detail, Node007, Message transaction complete
2017-10-19 14:48:36.352 Detail, Node007, Removing current message
2017-10-19 14:48:36.352 Detail, Node007, Notification: ValueChanged
2017-10-19 14:48:39.361 Detail, Node007, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x40, 0x03, 0x00, 0xb5
2017-10-19 14:48:39.361 Detail, Node007, Refreshed Value: old value=0, new value=0, type=list
2017-10-19 14:48:39.361 Detail, Node007, Changes to this value are not verified
2017-10-19 14:48:39.362 Info, Node007, Received thermostat mode: Off
2017-10-19 14:48:39.362 Detail, Node007, Notification: ValueChanged
2017-10-19 14:48:40.387 Info, Node007, Value::Set - COMMAND_CLASS_THERMOSTAT_MODE - Mode - 0 - 1 - Heat
2017-10-19 14:48:40.387 Detail, Node007, Queuing (Send) ThermostatModeCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x40, 0x01, 0x01, 0x25, 0x44, 0xc3
2017-10-19 14:48:40.387 Detail, Node007, Queuing (Send) ThermostatModeCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x40, 0x02, 0x25, 0x45, 0xc2
2017-10-19 14:48:40.388 Info, Node007, Sending (Send) message (Callback ID=0x44, Expected Reply=0x13) - ThermostatModeCmd_Set (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x40, 0x01, 0x01, 0x25, 0x44, 0xc3
2017-10-19 14:48:40.395 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-10-19 14:48:40.395 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2017-10-19 14:48:40.412 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0x44, 0x00, 0x00, 0x02, 0xad
2017-10-19 14:48:40.412 Detail, Node007, ZW_SEND_DATA Request with callback ID 0x44 received (expected 0x44)
2017-10-19 14:48:40.412 Info, Node007, Request RTT 24 Average Request RTT 24
2017-10-19 14:48:40.412 Detail, Expected callbackId was received
2017-10-19 14:48:40.413 Detail, Expected reply was received
2017-10-19 14:48:40.413 Detail, Message transaction complete
2017-10-19 14:48:40.413 Detail, Node007, Removing current message
2017-10-19 14:48:40.413 Info, Node007, Sending (Send) message (Callback ID=0x45, Expected Reply=0x04) - ThermostatModeCmd_Get (Node=7): 0x01, 0x09, 0x00, 0x13, 0x07, 0x02, 0x40, 0x02, 0x25, 0x45, 0xc2
2017-10-19 14:48:40.420 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-10-19 14:48:40.420 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2017-10-19 14:48:40.437 Detail, Node007, Received: 0x01, 0x07, 0x00, 0x13, 0x45, 0x00, 0x00, 0x02, 0xac
2017-10-19 14:48:40.437 Detail, Node007, ZW_SEND_DATA Request with callback ID 0x45 received (expected 0x45)
2017-10-19 14:48:40.437 Info, Node007, Request RTT 24 Average Request RTT 24
2017-10-19 14:48:40.438 Detail, Expected callbackId was received
2017-10-19 14:48:41.944 Detail, Node007, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x40, 0x03, 0x01, 0xb4
2017-10-19 14:48:41.944 Info, Node007, Response RTT 1530 Average Response RTT 1513
2017-10-19 14:48:41.944 Detail, Node007, Refreshed Value: old value=0, new value=1, type=list
2017-10-19 14:48:41.944 Detail, Node007, Changes to this value are not verified
2017-10-19 14:48:41.944 Info, Node007, Received thermostat mode: Heat
2017-10-19 14:48:41.944 Detail, Node007, Expected reply and command class was received
2017-10-19 14:48:41.944 Detail, Node007, Message transaction complete
2017-10-19 14:48:41.944 Detail, Node007, Removing current message
2017-10-19 14:48:41.944 Detail, Node007, Notification: ValueChanged
2017-10-19 14:48:44.949 Detail, Node007, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x07, 0x03, 0x40, 0x03, 0x01, 0xb4
2017-10-19 14:48:44.949 Detail, Node007, Refreshed Value: old value=1, new value=1, type=list
2017-10-19 14:48:44.949 Detail, Node007, Changes to this value are not verified
2017-10-19 14:48:44.949 Info, Node007, Received thermostat mode: Heat
2017-10-19 14:48:44.949 Detail, Node007, Notification: ValueChanged
Here are the OZW logs when I change the temperature set point which is not working:
2017-10-19 14:51:57.354 Info, Node007, Value::Set - COMMAND_CLASS_THERMOSTAT_SETPOINT - Away Heating - 13 - 1 - 67
2017-10-19 14:51:57.354 Detail, Node007, Queuing (Send) ThermostatSetpointCmd_Set (Node=7): 0x01, 0x0c, 0x00, 0x13, 0x07, 0x05, 0x43, 0x01, 0x0d, 0x01, 0x43, 0x25, 0x46, 0x8c
2017-10-19 14:51:57.354 Detail, Node007, Queuing (Send) ThermostatSetpointCmd_Get (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x43, 0x02, 0x0d, 0x25, 0x47, 0xcc
2017-10-19 14:51:57.355 Detail,
2017-10-19 14:51:57.355 Info, Node007, Sending (Send) message (Callback ID=0x46, Expected Reply=0x13) - ThermostatSetpointCmd_Set (Node=7): 0x01, 0x0c, 0x00, 0x13, 0x07, 0x05, 0x43, 0x01, 0x0d, 0x01, 0x43, 0x25, 0x46, 0x8c
2017-10-19 14:51:58.355 Error, Node007, ERROR: Dropping command, expected response not received after 1 attempt(s)
2017-10-19 14:51:58.355 Detail, Node007, Removing current message
2017-10-19 14:51:58.355 Detail, Node007, Notification: Notification - TimeOut
2017-10-19 14:51:58.357 Detail,
2017-10-19 14:51:58.357 Info, Node007, Sending (Send) message (Callback ID=0x47, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x43, 0x02, 0x0d, 0x25, 0x47, 0xcc
2017-10-19 14:51:58.358 Detail, Node007, CAN received…triggering resend
2017-10-19 14:51:58.358 Info, Node007, Sending (Send) message (Attempt 2, Callback ID=0x48, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x43, 0x02, 0x0d, 0x25, 0x48, 0xc3
2017-10-19 14:51:58.359 Detail, Node007, CAN received…triggering resend
2017-10-19 14:51:58.359 Info, Node007, Sending (Send) message (Attempt 3, Callback ID=0x49, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x43, 0x02, 0x0d, 0x25, 0x49, 0xc2
2017-10-19 14:51:58.360 Detail, Node007, CAN received…triggering resend
2017-10-19 14:51:58.360 Info, Node007, Sending (Send) message (Attempt 4, Callback ID=0x4a, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x43, 0x02, 0x0d, 0x25, 0x4a, 0xc1
2017-10-19 14:51:58.361 Detail, Node007, CAN received…triggering resend
2017-10-19 14:51:58.362 Info, Node007, Sending (Send) message (Attempt 5, Callback ID=0x4b, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x43, 0x02, 0x0d, 0x25, 0x4b, 0xc0
2017-10-19 14:51:58.363 Detail, Node007, CAN received…triggering resend
2017-10-19 14:51:58.363 Info, Node007, Sending (Send) message (Attempt 6, Callback ID=0x4c, Expected Reply=0x04) - ThermostatSetpointCmd_Get (Node=7): 0x01, 0x0a, 0x00, 0x13, 0x07, 0x03, 0x43, 0x02, 0x0d, 0x25, 0x4c, 0xc7
2017-10-19 14:51:58.363 Detail, Unsolicited message received while waiting for ACK.
2017-10-19 14:51:58.363 Detail, Node007, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-10-19 14:51:58.363 Detail, Node007, ZW_SEND_DATA delivered to Z-Wave stack
2017-10-19 14:51:58.364 Detail, Node007, CAN received…triggering resend
2017-10-19 14:51:58.364 Error, Node007, ERROR: Dropping command, expected response not received after 6 attempt(s)
2017-10-19 14:51:58.364 Detail, Node007, Removing current message
2017-10-19 14:51:58.365 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0x46, 0x00, 0x00, 0x02, 0xaf
2017-10-19 14:51:58.365 Detail, ZW_SEND_DATA Request with callback ID 0x46 received (expected 0x00)
2017-10-19 14:51:58.365 Warning, WARNING: Unexpected Callback ID received
Edit:
I just realized that the set point temp it is reporting is the temperature from the thermostat temp sensor. Its not getting the set point temperature as well as not setting it.
Here is the “heat” setting entity on my thermostat:
