I just got 2 new Gledopto lights that I’m using with deconz. They are great, however the transition to off takes way too long.
In an attempt to make this faster I changed “transition” to 0.5 seconds for the toggle event. It works in the part of making the turning on and off faster, but:
- after toggling a light off with the transition option set, the next time I toggle it on, it is set to the most dim brightness setting
I suspect it saves the brightness from transitioning to the “0” level = off.
But is there any way to change this? This can’t be expected behavior. As soon as I delete the transition option its going back to normal.
