Transition from Sonoff dongle coordinator P to the SLZB-06
Hello to all present.
Transition from Sonoff dongle coordinator P to the SLZB-06.
The reason was to switch to Lan.
But SLZB-06 do not work well, even though I started from the beginning, a brand new pairing.
I uninstalled Zigbee2MQTT and deleted the Zigbee2MQTT folder.
I turned off for a while to power the network elements.
After the Home Assistant restart, I installed Zigbee2MQTT.
He set up settings and began to pair the devices gradually.
Now I have a network problem. The equipment is disconnected, have large delays.
I have a new connection for four days, but still the same.
Another firmware does not help. Home Assistant Updated
Starting firmware: v2.3.6
Coordinator mode: LAN
Radio FW version: 20240315
Device type: SLZB-06
Radio mode: ZB COORD
ETH static IP config: OK
internet | connected
Very weak LQI between 0 to max 30 (terminal devices: 52, router: 44)
The Sonoff Dongle P was LQI 50 to 150.
I’m still looking for where there may be a mistake.
Maybe I have faulty SLZB-06, or just a defective antenna?
Please don’t be angry with what type of antenna is at SLZB-06 (Connector)?
2024.07.28 16:20 - Currently FW 20221226
I will leave it for two days, maybe it will improve.
Hello I’am in the same situation. I switched from sonoff dongle to slzb-06 because I moved my server in basement and lan adapter is perfect for this. I switch the coordinator without problem and also added other two slzb-06 as a router. But every day I loose 3-4 devices and I need to repair it. ot is very annoying. Have someone find the solution?
I’m about to do that switch but your posts are making me nervous. Did you ever find the cause? Zigbee mesh issues?
