I am running Home Assistant Supervised on an RPi4. I have my Jasco Dimmer Plugs connected through ZWaveJS. The plugs work great and dim my lights appropriately (they do seem to hit max brightness at around ~70%, but that’s not a major issue).
The only problem I’m running into is regarding the transition. From what I can see the plugs should support transition (they show supported_features: 33 in developer tools, which from my understanding means they support brightness + transition). But it simply ignores it and immediately moves to the new brightness. Here is my automation:
alias: Turn on living room lights at sunset
description: ''
- platform: sun
event: sunset
offset: '-00:40:00'
condition: []
- service: light.turn_on
transition: 60
brightness_pct: 50
entity_id:
- light.plug_in_smart_dimmer_single_plug
- light.plug_in_smart_dimmer_single_plug_2
mode: single
When I run it the lights just immediately go to 50%. I’m testing it with 60s right now but my “end goal” is to have them ramp up over ~30 minutes.
Has anyone successfully used transition with a Z-Wave Jasco dimmer plug? Or is there another way to accomplish what I’m looking to do?
