Transition stops working
SOLVED: Issue was within Zigbee2mqtt. After last update it started to work again.
I’ve notice the transition for one light just stops working. I had it set for 120s. to turn off, but instead it turns off instantly. Seems like it happened after the 2024.8 update. So far, with the 2024.9 it has not been resolved.
This is my config:
alias: Bed light slow off
description: ""
  - platform: webhook
    allowed_methods:
      - POST
      - PUT
    local_only: true
    webhook_id: bed-light-slow-off-###################
  - platform: device
    domain: mqtt
    device_id: c35e7245715fcbc452518e6c22798b91
    type: action
    subtype: "off"
  - platform: device
    domain: mqtt
    type: action
    subtype: "on"
condition:
  - condition: device
    device_id: 11ce12696626d9000e069b977ea64c5f
    domain: device_tracker
    entity_id: ba09859e8d901b1b010138a54217dc23
    type: is_home
  - choose:
      - conditions:
          - condition: trigger
            id:
              - Webhook
              - Switch off
        sequence:
          - action: light.turn_off
              device_id:
                - 871ea5b361fc699cb8c0ce24160609f4
              transition: 120
      - conditions:
            id:
              - Switch on
        sequence:
          - metadata: {}
              brightness_pct: 100
              transition: 5
              kelvin: 6001
              device_id: 871ea5b361fc699cb8c0ce24160609f4
            action: light.turn_on
            enabled: true
mode: single
