Transitions not working correctly
Hey guys - so I’ve been moving all my Zigbee lights to zigbee2mqtt and been pretty happy with the results. One strange things I’ve come across is that when I call light.turn_on with a transition, IF the bulb was off, then the transition is completely ignored and the bulb goes too 100% right away. If I issue the same setting and the bulb is on, even at 1%, the transition is correctly obeyed. Has anyone else seen this? I’m running 0.96.5 via hass.io and zigbee2mqtt 1.5.1.
What lights?
Ecosmart bulbs.
