Hi , do you know if there is a possibility to translate into another language?
I tried searching on the forum and found nothing … something like Friendly Name
Thanks!
Thanks!
You could do this with a sensor template. I use this method with device tracker entries for my PCs to change the values from home and not home to system up and system down.
thanks for the reply … I would translate the entire popup that appears when I click on “Sun” icon … is it possible?
Yes, you can but I’m not sure if you can add stuff as attributes to a template sensor. The example in the documentation is a good point to start.
