trying to get a sensor value, translated (via an automation?) which then resets (hopefully) the counter of the sensor and saves the value - I have tried now to do this through an automation - but I would appreciate some help as:
→ the translated value based on the number of the count during the 5s seems to work but is not being saved as I thought it would within the automation “capture flow rate and reset pulse counter” (reset of the pulse counter seems to be working)
here is the yaml I am using:
#ref : https://github.com/jdeneef/ha_gpiod
binary_sensor:
- platform: gpiod
sensors:
- name: "water_flow_sensor" #eg YFB10
port: 23
debounce: 0
# Input number to store the flow rate every 5 seconds
input_number:
water_flow_rate_5s:
name: Water Flow Rate (5s)
min: 0
max: 100000
step: 0.01
unit_of_measurement: "l/min"
counter:
water_meter_pulses_interval:
name: Water Meter Pulses Interval
initial: 0
step: 1
water_meter_pulses_total:
name: Water Meter Pulses Total
initial: 0
step: 1
automation water_meter_counter:
- alias: Count Water Meter Pulses in Interval
- platform: state
entity_id: binary_sensor.gpiod_gpiod_23_water_flow_sensor
to: 'on'
- service: counter.increment
entity_id: counter.water_meter_pulses_interval
- alias: Count Water Meter Pulses total
- platform: state
to: 'on'
entity_id: counter.water_meter_pulses_total
# Automation to capture the flow rate every 5 seconds and then reset the counter
- alias: Capture Flow Rate and Reset Pulse Counter
- platform: time_pattern
seconds: '/5'
- variables:
pulse_count: "{{ states('counter.water_meter_pulses_interval') | int }}"
- service: input_number.set_value
entity_id: input_number.water_flow_rate_5s
value: >
{% set threshold = 10 %}
{% set pulses_per_liter_low = 10 %}
{% set pulses_per_liter_high = 6 %}
{% if pulse_count <= threshold %}
{% set flow_rate = (pulse_count / pulses_per_liter_low) * (60 / 5) %}
{% else %}
{% set flow_rate = (pulse_count / pulses_per_liter_high) * (60 / 5) %}
{% endif %}
{{ flow_rate | round(2) }}
- service: counter.reset
# Template sensor to display the latest captured flow rate
sensors:
water_flow_rate:
friendly_name: "Water Flow Rate"
value_template: "{{ states('input_number.water_flow_rate_5s') }}"
utility_meter:
quarter_hourly_water_usage:
source: input_number.water_flow_rate
cycle: quarter-hourly
hourly_water_usage:
cycle: hourly
daily_water_usage:
cycle: daily
weekly_water_usage:
cycle: weekly
monthly_water_usage:
cycle: monthly
any help is appreciated!!
