I have an automation with a template that looks like this:
- data_template:
entity_id: media_player.sonos_4
message: Light level {{states.sensor.ihome_smartmonitor_a26825_light_level.state|round}}
lux and humidity is {{states.sensor.ihome_smartmonitor_a26825_humidity.state|round}} percent.
service: tts.google_translate_say
Is there an easy way to refer to entity values embedded in a message like this in Node Red? Or do I have to retrieve each value individually to a variable and then combine them into a message and then output the message as a bunch of separate steps?
You can give this a try. Personally I never used it like you intend to yet but would be interesting to simplify some flows:
https://zachowj.github.io/node-red-contrib-home-assistant-websocket/guide/mustache-templates.html
EDIT
Works fine. Here an example for my Alexa Voice Service Call:
"title": "Home Assistant",
"message": "{{entity.light.kitchen_top.attributes.friendly_name}}",
"data": {
"type": "announce",
"method": "all"
Thank you, that was the hint I needed. Sometimes it’s very difficult to find a specific example with a search when you don’t know exactly what you’re looking for.
For me the message that works in Node Red is then:
"message": "Light level {{entity.sensor.ihome_smartmonitor_a26825_light_level}} lux
and humidity is {{entity.sensor.ihome_smartmonitor_a26825_humidity.state}} percent."
Just to add some keywords that search engines can index for those looking for similar information:
Node Red, embed Home Assistant entity attribute value, curly moustache brackets
