"Translation Error" in automation with Bosch Smart Home Switch
Hello everyone,
I have been looking for this problem for days, but can’t find any clues to solve it.
After updating to 2024.4.1, my automation displays the following message in the trace timeline:
Translation error: The intl string context variable “reason” was not provided to the string “Stopped for unknown reason {reason} at {time} (runtime: {executiontime} seconds)”
I have not changed anything in the automation and it worked before without any problems.
Any hints or tips on what I can do?
Many thanks in advance.
You would need to provide some yaml for us to help.
How to help us help you - or How to ask a good question.
Hello @Sir_Goodenough .
Thanks for your message.
The YAML is the following:
alias: Licht Wohnzimmer
description: ""
  - platform: device
    device_id: 18b234665cafd58dca7803bef7f50dfe
    domain: bosch_shc
    type: PRESS_LONG
    subtype: LOWER_BUTTON
  - platform: device
    domain: bosch_shc
    type: PRESS_SHORT
condition: []
  - choose:
      - conditions:
          - condition: trigger
          - condition: state
            entity_id: light.lichter_wohnzimmer
            state: "off"
        sequence:
          - service: light.turn_on
              brightness_pct: 30
              transition: 10
              kelvin: 2700
          - choose:
              - conditions:
                  - condition: device
                    device_id: f8a48aa83df7e787c5a8d61ae07cbadf
                    domain: media_player
                    entity_id: media_player.samsung_q95t
                    type: is_off
                sequence:
                  - device_id: 0b07d9e5a6423c359a70e5b6800bfb4a
                    domain: select
                    entity_id: 754c86a08006a8b0cab082e454596586
                    type: select_option
                    option: Warm Weiß
                  - device_id: 228cf8ad3966f44ba24a781853eca0f3
                    domain: select
                    entity_id: 2cbde699c42aa9b0ce3bb8a6873ca1a7
                    type: select_option
                    option: Warm Weiß
              - conditions:
                  - condition: device
                    type: is_on
                  - condition: device
                    device_id: f791d35281808bb0068a9d2e54d732d8
                    domain: device_tracker
                    entity_id: da548a9ee21c3ef27de30e47a2a97e7e
                    type: is_home
                sequence:
                    domain: select
                    type: select_option
                    option: "Christmas "
                    domain: select
                    type: select_option
                    option: Christmas
              - conditions:
                  - condition: device
                    type: is_on
                  - condition: device
                    type: is_not_home
                sequence:
                    domain: select
                    type: select_option
                    option: Mirko
                    domain: select
                    type: select_option
                    option: Mirko
      - conditions:
          - condition: state
            state: "on"
        sequence:
          - service: light.turn_off
              transition: 10
      - conditions:
          - condition: or
            conditions:
              - condition: device
                device_id: 4d31d44d64d569969eed31c5a15ba0a3
                domain: alarm_control_panel
                entity_id: alarm_control_panel.intrusion_detection_system
                type: is_armed_home
              - condition: device
                type: is_armed_away
              - condition: device
                type: is_triggered
        sequence:
          - device_id: 4d31d44d64d569969eed31c5a15ba0a3
            type: disarm
          - delay:
              hours: 0
              minutes: 0
              seconds: 3
              milliseconds: 0
          - service: automation.trigger
              skip_condition: false
              entity_id: automation.rollladen_morgens_hoch
mode: single
Regards
You are using all device triggers which are not user friendly and are very hard for me to diagnose. I don’t see a problem, though.
The error is not talking about the automation at all, just complaining about a language problem when trying to provide an error message I think. Clear the core log then run it again, see if there is another error.
Did you look at the trace and see what is working and what isn’t. That will be your best bet to fixing this. And sending me pictures of the trace is not going to help me. Also look at what it thinks the variables are in the automation when it runs, and check that the variables are what you think they are supposed to be.
I have now created a new automation and tested it. When I configure the trigger with device, the button press is recognized. But the error appears.
If I configure the trigger as a changing entity, the automation works.
If I press the switch too many times in succession, the Home Assistant crashes. It’s all very strange.
I will test further.
Thank you for your input.
So found another user posting this on Discord.
Discord.
The suggestion was for them to open a core issue for the problem. I would suggest you look to see if there was one opened. That Discord post was posted April 9.
If you don’t see one you should open an issue in frontend. Provide all the info you can including your default language settings and an automation that shows the problem, the error message, and pics of the trace and history if you can.
Reporting issues - Home Assistant.
Issues · home-assistant/frontend · GitHub.
(Edited to Frontend instead of core)
This should be the frontend fix for this error string:
I will do it. Thank you :+1:
