Translation error - italian language - after 2025.2.2 update
After updating HA core (in docker) from 2025.2.1 to 2025.2.2 I get the following error in logs:
Registratore: frontend.js.modern.202502100
Fonte: components/system_log/__init__.py:331
Prima occorrenza: 07:41:39 (14 occorrenze)
Ultimo accesso: 11:56:35
Failed to format translation for key 'ui.panel.config.tips.join' in language 'it'. Error: The intl string context variable "mastodon" was not provided to the string "Unisciti alla comunità sui nostri {forums}, {mastodon}, {bluesky}, {twitter}, {discord}, {blog} o {newsletter}"
Switching to english language the error obviously do not occur.
The bottom page tip shows it:
same in Swedish
it looks like there’s a global issue for all languages exept english. It’s already opened an issue on github:
https://github.com/home-assistant/core/issues/138258
Issue solved with 2025.2.4 update
