Hello everyone. I am trying to add the integration but when configuring it it fails in its connection. I show them the remote configuration of the application to see if anyone sees something that is wrong. The computer where the application is installed is at address 192.168.1.50 and it is this number that I put in the integration when adding the integration. I clarify everything in case something I’m doing is wrong. Thank you very much
In case it serves to someone. The problem was the port. I used a port more something or different and it worked.
