Hey!
Anybody got an idea how to make the header transparent using themes?
I’m trying to figure it out myself. I’m half way there. Using the following, I can get the header to be transparent, but only after scrolling down a bit. There’s still a black (or other dark color) band behind the header at the top, making it look black until scrolling. I really want it to be transparent the whole time.
app-header-background-color: "rgba(0, 0, 0, 0.4)"
The last number is the transparency value. I’ve tried adding the following line too, but it has no effect.
app-toolbar-background-color: "rgba(0, 0, 0, 0.1)"
Here’s what mine looks like before and after scrolling:
I would love it to look like the second image without having to scroll. Anyone have any ideas?
Looks like there is also an issue raised on github for this.
Any idea? Same issue here
Since latest update I can’t even get it to be transparent at all
Same here. The workaround no longer works and I haven’t found the trick yet…
Still no solution for this?
HA 2023.4 had a frontend library being replace due to deprecation. In version 2023.3, I used card-mod in themes to set a background image behind the header using CSS tags ha-app-layout and made the app-header transparent. This is not possible anymore, I found a new workaround for 2023.4 to set a background image and transparent header using card-mod:
card-mod-theme: <name_of_theme>
card-mod-root: |
#view {
background: url('/local/img/background.png');
background-size: cover;
margin-top: auto !important;
height: calc(100vh - env(safe-area-inset-top)) !important;
.header {
background: rgba(20,20,20,0.3) !important;
card-mod-view-yaml: |
hui-view {
background: none !important;
hui-masonry-view {
padding-top: var(--header-height);
This workaround is not necessary anymore after HA 2023.5
Is it possible to make the header/toolbar permanently transparent and show the background at the moment?
I have set
app-header-background-color: "rgba(0, 0, 0, 0)"
app-toolbar-background-color: "rgba(0, 0, 0, 0)"
in my theme but the toolbar/header only becomes transparent on scrolling.
not sure if this is closed but I found a working workaround. It is using a theme but here is the code:
Theme:
# Home Assistant override
ha-card-box-shadow: 0px 2px 4px 0px rgba(0,0,0,0.16)
ha-card-border-width: 0
app-header-background-color: "transparent"
app-header-text-color: "white"
style: |
#customSidebar {
width: 18.5%;
overflow: hidden;
margin-top: 0px !important;
#view {
padding-top: 0px !important;
#tabsContainer {
display: none;
Anyone found a good workaround that works?
