First sensor to query Transport NSW for bus, ferry and train times. Works great to build a bus/train/ferry monitor with information on next transport option.
First get your free API key from https://opendata.transport.nsw.gov.au/ .
Next download the transport_nsw.py sensor into your custom_components folder
Transport NSW sensor to query next leave event for a specified stop.
import logging
from datetime import timedelta, datetime
import requests
import voluptuous as vol
import homeassistant.helpers.config_validation as cv
import homeassistant.util.dt as dt_util
from homeassistant.components.sensor import PLATFORM_SCHEMA
from homeassistant.const import CONF_NAME, ATTR_ATTRIBUTION
from homeassistant.helpers.entity import Entity
_LOGGER = logging.getLogger(__name__)
ATTR_STOP_ID = 'stopid'
ATTR_ROUTE = 'route'
ATTR_DUE_IN = 'due'
ATTR_DELAY = 'delay'
ATTR_REALTIME = 'realtime'
CONF_ATTRIBUTION = "Data provided by Transport NSW"
CONF_STOP_ID = 'stopid'
CONF_ROUTE = 'route'
CONF_APIKEY = 'apikey'
DEFAULT_NAME = "Next Bus"
ICON = "mdi:bus"
SCAN_INTERVAL = timedelta(minutes=1)
TIME_STR_FORMAT = "%H:%M"
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend({
vol.Required(CONF_STOP_ID): cv.string,
vol.Required(CONF_APIKEY): cv.string,
vol.Optional(CONF_NAME, default=DEFAULT_NAME): cv.string,
vol.Optional(CONF_ROUTE, default=""): cv.string,
def setup_platform(hass, config, add_devices, discovery_info=None):
"""Set up the Transport NSW sensor."""
name = config.get(CONF_NAME)
stopid = config.get(CONF_STOP_ID)
route = config.get(CONF_ROUTE)
apikey = config.get(CONF_APIKEY)
data = PublicTransportData(stopid, route, apikey)
add_devices([TransportNSWSensor(data, stopid, route, name)], True)
class TransportNSWSensor(Entity):
"""Implementation of an Transport NSW sensor."""
def __init__(self, data, stopid, route, name):
"""Initialize the sensor."""
self.data = data
self._name = name
self._stopid = stopid
self._route = route
self._times = self._state = None
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def state(self):
"""Return the state of the sensor."""
return self._state
@property
def device_state_attributes(self):
"""Return the state attributes."""
if self._times is not None:
return {
ATTR_DUE_IN: self._times[0][ATTR_DUE_IN],
ATTR_STOP_ID: self._stopid,
ATTR_ROUTE: self._times[0][ATTR_ROUTE],
ATTR_DELAY: self._times[0][ATTR_DELAY],
ATTR_REALTIME: self._times[0][ATTR_REALTIME],
ATTR_ATTRIBUTION: CONF_ATTRIBUTION
@property
def unit_of_measurement(self):
"""Return the unit this state is expressed in."""
return 'min'
@property
def icon(self):
"""Icon to use in the frontend, if any."""
return ICON
def update(self):
"""Get the latest data from Transport NSW and update the states."""
self.data.update()
self._times = self.data.info
try:
self._state = self._times[0][ATTR_DUE_IN]
except TypeError:
pass
class PublicTransportData(object):
"""The Class for handling the data retrieval."""
def __init__(self, stopid, route, apikey):
"""Initialize the data object."""
self.stopid = stopid
self.route = route
self.apikey = apikey
self.info = [{ATTR_ROUTE: self.route,
ATTR_DUE_IN: 'n/a',
ATTR_DELAY: 'n/a',
ATTR_REALTIME: 'n/a'}]
def update(self):
"""Get the latest data from Transport NSW."""
url = ("https://api.transport.nsw.gov.au/v1/tp/departure_mon?"
"outputFormat=rapidJSON&"
"coordOutputFormat=EPSG%3A4326&"
"mode=direct&"
"type_dm=stop&"
"name_dm="+self.stopid+"&"
"departureMonitorMacro=true&"
"TfNSWDM=true&"
"version=10.2.1.42")
auth = 'apikey ' + self.apikey
header = {'Accept': 'application/json',
'Authorization': auth}
response = requests.get(url, headers=header, timeout=10)
_LOGGER.debug(response)
# No valid request, set to default
if response.status_code != 200:
_LOGGER.error(response.status_code)
ATTR_DUE_IN: 'n/a',
ATTR_DELAY: 'n/a',
return
# Parse the result as a JSON object
result = response.json()
# No stop events for the query
if len(result['stopEvents']) <= 0:
_LOGGER.error("No stop events for this query")
ATTR_DUE_IN: 'n/a',
ATTR_DELAY: 'n/a',
return
# Set timestamp format and variables
fmt = "%Y-%m-%dT%H:%M:%SZ"
maxresults = 3
monitor = []
if self.route != '':
# Find any bus leaving next
for i in range(len(result['stopEvents'])):
number = result['stopEvents'][i]['transportation']['number']
if number == self.route:
planned = datetime.strptime(
result['stopEvents'][i]['departureTimePlanned'],
fmt)
realtime = 'n'
estimated = planned
delay = 0
if 'isRealtimeControlled' in result['stopEvents'][i]:
realtime = 'y'
estimated = datetime.strptime(
result['stopEvents'][i]['departureTimeEstimated'],
fmt)
if estimated > datetime.utcnow():
due = round((estimated - datetime.utcnow()).seconds/60)
if estimated >= planned:
delay = round((estimated-planned).seconds/60)
else:
delay = round((planned-estimated).seconds/60) * -1
monitor.append(
[number, due, delay, planned, estimated, realtime])
if len(monitor) >= maxresults:
# We found enough results, lets stop
break
else:
# Find the next stop events
for i in range(0, maxresults):
fmt)
realtime = 'n'
estimated = planned
delay = 0
realtime = 'y'
fmt)
else:
monitor.append(
if len(monitor) > 0:
self.info = [{ATTR_ROUTE: monitor[0][0],
ATTR_DUE_IN: monitor[0][1],
ATTR_DELAY: monitor[0][2],
ATTR_REALTIME: monitor[0][5]}]
return
else:
# _LOGGER.error("No stop events for this route.")
ATTR_DUE_IN: 'n/a',
ATTR_DELAY: 'n/a',
return
Next create your sensor to query the data. In order to find the stop id, just go to Google maps and click on the bus/train/ferry stop. It will give you there the stop ID.
You can define a bus line, but if you donāt do it, the sensor will pick up the next stop event from any line servicing this stop.
- platform: transport_nsw
stopid: '200024'
route: 'E80'
apikey: 'YOUR API KEY'
I have done some testing and it works fine for me. Let me know if you have any feedback.
