Treadlife DS03 - disconnect pushbutton from MCU
Hey all,
I have some for fan/light dimmers Treadlife DS03 installed. Now I want to replace lightbulbs with Zigbee ones. Problem is that Zigbee bulbs like to have power always on.
Is there a way, to disconnect the physical pushbutton from MCU? I would still like to have the status of the pushbutton and dimming level sent to HA, where automation will send it. to the bulbs.
I know, that I can connect bulbs bypassing dimmer, but I would like to have some failsafe relay just in case they will freak out.
Thanks,
After some searching, looks like I’m stuck with hotwiring smart bulbs. Pushbuttons in Tuya dimmers are direct connected to MCU and can’t be disjointed.
The only wall dimmer, I’ve found, which allows “always on” load is Inovelli Red.
