Home Assistant Core 2018.8.6
Python 3.9.1
I think this problem started after installing 2018.8.3
If I reboot HA starts up no problem
If I restart HA, I get the following:
[1776242592] The system cannot restart because the configuration is not valid: Platform error binary_sensor.trend - IMPORTANT: PLEASE READ THIS FOR ADVICE ON HOW TO SOLVE THIS ISSUE! Importing the numpy C-extensions failed. This error can happen for many reasons, often due to issues with your setup or how NumPy was installed. We have compiled some common reasons and troubleshooting tips at: https://numpy.org/devdocs/user/troubleshooting-importerror.html Please note and check the following: * The Python version is: Python3.9 from "/srv/homeassistant/bin/python3" * The NumPy version is: "1.21.1" and make sure that they are the versions you expect. Please carefully study the documentation linked above for further help. Original error was: /lib/arm-linux-gnueabihf/libm.so.6: version `GLIBC_2.29' not found (required by /srv/homeassistant/lib/python3.9/site-packages/numpy/core/_multiarray_umath.cpython-39-arm-linux-gnueabihf.so)
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/websocket_api/commands.py", line 185, in handle_call_service
await hass.services.async_call(
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/core.py", line 1491, in async_call
task.result()
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/core.py", line 1526, in _execute_service
await handler.job.target(service_call)
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/helpers/service.py", line 728, in admin_handler
await result
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/homeassistant/__init__.py", line 161, in async_handle_core_service
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: The system cannot restart because the configuration is not valid: Platform error binary_sensor.trend -
installed.
I’ve tried:
apt-get install libatlas-base-dev libjpeg-dev
pip3 install numpy --no-cache-dir --force-reinstall --no-binary :all:
Any thoughts or ideas?
