I’m trying to have a sensor using Xiaomi Thermometer with BTHome firmware but it seems I do not find the proper values.
My idea is to have the trend displayed when the temp changes with 0.2 degrees in a period of 15minutes. The thermometer seems to refresh every 70 seconds.
When asking for help, please post the whole configuration that is in question. There may be other issues that we can’t see.
The value of max_samples has to be an integer, there’s no such thing as fractional samples. You need to set the value to a number that makes sense for the length of your duration as well as how often your sensor pushes updates… so it should be 13 or higher.
