Trial Month Home Assistant Cloud
Hi everyone, I started the Home Assistant Cloud trial month on my Unraid Home Assistant VM, the problem is that I can’t access my server from outside the house, from the iPhone I get to the login screen using the link provided, but it always tells me that user or pass are wrong, I tried both with the Home Assistant login credentials and with the Nabu account, but with the same result, it won’t let me in, while I tried to use the same link from PC with the same login credentials (Home Assistant) and from there it works!
Does anyone have any idea what the problem could be?
You can open a support ticket here after checking the configuration instructions and trying the troubleshooting steps listed on the page:
Ok Thanks!
