Hi everyone,
About a month ago I ordered this ESP32-S Cam from China , which arrived in the beginning of this week. Since then I’ve been trying to get it to work, but without any luck. Do you have any suggestions?
All the facts + logs:
Home Assistant: 0.92.2
ESPHome: 1.12.2
The module:
[Note: The RX and TX aren’t connected on the FTDI adapter side]
The yaml file:
esphome:
platform: ESP32
board: esp32dev
wifi:
ssid: "myssid"
password: "ssidpassword"
# Enable logging
logger:
api:
password: 'apipassword'
reboot_timeout: 0s
ota:
safe_mode: True
password: 'otapassword'
esp32_camera:
external_clock:
pin: GPIO0
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
The log:
[22:18:42][C][wifi:371]: WiFi:
[22:18:42][C][wifi:253]: SSID: 'myssid'[redacted]
[22:18:42][C][wifi:254]: IP Address: xxxxxxx[redacted]
[22:18:42][C][wifi:256]: BSSID: xxxxx [redacted]
[22:18:42][C][wifi:257]: Hostname: 'esp32_1'
[22:18:42][C][wifi:261]: Signal strength: -64 dB ▂▄▆█
[22:18:42][C][wifi:262]: Channel: 6
[22:18:42][C][wifi:263]: Subnet: xxxxx[redacted]
[22:18:42][C][wifi:264]: Gateway: xxxxx[redacted]
[22:18:42][C][wifi:265]: DNS1: xxxxx[redacted]
[22:18:42][C][wifi:266]: DNS2: 0.0.0.0
[22:18:42][C][logger:142]: Logger:
[22:18:42][C][logger:143]: Level: DEBUG
[22:18:42][C][logger:144]: Log Baud Rate: 115200
[22:18:42][C][logger:145]: Hardware UART: UART0
[22:18:42][C][esp32_camera:044]: ESP32 Camera:
[22:18:42][C][esp32_camera:045]: Name: My Camera
[22:18:42][C][esp32_camera:046]: Board Has PSRAM: YES
[22:18:42][C][esp32_camera:048]: Data Pins: D0:5 D1:18 D2:19 D3:21 D4:36 D5:39 D6:34 D7:35
[22:18:42][C][esp32_camera:049]: VSYNC Pin: 25
[22:18:42][C][esp32_camera:050]: HREF Pin: 23
[22:18:42][C][esp32_camera:051]: Pixel Clock Pin: 22
[22:18:42][C][esp32_camera:052]: External Clock: Pin:0 Frequency:20000000
[22:18:42][C][esp32_camera:053]: I2C Pins: SDA:26 SCL:27
[22:18:42][C][esp32_camera:054]: Reset Pin: -1
[22:18:42][C][esp32_camera:075]: Resolution: 640x480 (VGA)
[22:18:42][E][esp32_camera:092]: Setup Failed: ERROR
[22:18:42][C][api:101]: API Server:
[22:18:42][C][api:102]: Address: esp32_1.local:6053
[22:18:42][C][ota:127]: Over-The-Air Updates:
[22:18:42][C][ota:128]: Address: esp32_1.local:3232
[22:18:42][C][ota:130]: Using Password.
See my post below for the list with things I tried, since I can’t post more than 2 links in 1 post as a new user.
Ivan711
(Ivan711)
May 14, 2019, 8:20pm
2
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
resolution: 640x480
jpeg_quality: 10
Akriss
(kris)
May 14, 2019, 9:52pm
3
Maybe the camera module is not aligned with the holder/socket correctly?
Have a photo of the other side of the module? I ask because I’ve not seen that exact module before. Most esp32 camera modules I’ve seen have different markings.
You could try the possess of elimination and try every camera setting there are. There are only four configs known atm so it would be a quick process to try.
Hope its of help.
Klagio
(Klagio)
May 29, 2019, 8:04pm
4
Getslow:
The module:
have you managed? I think I have the same cam, and tried 3 different settings, but all give same error as yours
Akriss
(kris)
May 29, 2019, 8:27pm
5
I’ve seen that error.
I damaged the camera module during tinkering, think I may have crushed it wile putting it in a enclosure.
Swapping the camera module works in my case.
Klagio
(Klagio)
June 8, 2019, 9:41am
6
I have a working config, data_pinshas to be in the below exact ORDER
esphome:
platform: ESP32
board: esp32dev
substitutions:
# Modify variables based on your settings
hostname: 'Cam'
wifi:
networks:
- ssid: "fff"
password: "vvv"
- ssid: vvv
password: ccc
manual_ip:
static_ip: 192.168.1.21
gateway: 192.168.1.254
subnet: 255.255.255.0
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
port: 80
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
output:
#flashlight
- platform: gpio
pin: GPIO4
#statuslight
- platform: gpio
pin:
number: GPIO33
inverted: True
light:
#flashlight
- platform: binary
output: gpio_4
#statuslight
- platform: binary
output: gpio_33
- platform: wifi_signal
name: $hostname WiFi Signal
update_interval: 60s
- platform: uptime
text_sensor:
- platform: version
name: $hostname ESPHome Version
- platform: wifi_info
ssid:
switch:
- platform: restart
binary_sensor:
- platform: status
# on_state:
# then:
# - light.turn_on: light.cam_status
# off_state:
# then:
# - light.turn_off: light.cam_status
N8Rtz
(Nathan)
February 18, 2022, 3:39pm
7
I hate to revive an old thread, but I just want to thank you for posting this. I’ve been bashing my head for weeks trying to get my esp32cam to work and your code did it for me.
PapaLanc
(Grey Lancaster)
July 31, 2022, 5:06pm
8
@Klagio
worked for me
thanks
Klagio:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
vsync_pin: GPIO25
href_pin: GPIO23
Well I ended up copying all and that extra stuff is sweet !!
