I was trying to set up DuckDNS to access my Home Assistant remotely, and now I can’t log in at all.
I am getting an error " NSURLErrorDomain Code -1005".
I have a monitor connected to the computer that it is running on (Home Assistant Blue), the command line is showing up, I don’t see any errors. It shows the correct ‘Home Assistant URL’. I can also access the home assistant via Samba, so I can edit the config files if necessary. I also have access to the ‘ssl’ directory which contains the fullchain.pem privkey.pem files if there’s something I need to edit or remove there.
Can someone please help me to figure out how to restore access to the home assistant?
You should still be able to access https://<ip_address>:8123 locally. Though you will have to add a security exception to your web browser to ignore the ssl certificate.
Not yet, I tried from my Mac and from my iPhone. Didn’t try the PC.
If I uncomment the lines out that I mentioned and reboot, are you saying that I should then be able to log in via https://? Since I now know I can recover the computer if it doesn’t work, I may try resetting it to see if it works.
I appreciate your assistance. Can’t tell you how much anxiety it caused me when it wouldn’t log in.
Seems like mostly realated to Iphone, Mac and the “browsers” used there … maybe firefox will get you “through” … and in regards to mac/ipho im “out” , sorry, i don’t even intend to get “inside” this “area”
Logging in with Trusted Networks.
Login aborted:
Your computer is not allowed.
[START OVER]
I tried turning off all ‘content blockers’ in the security settings of my browser (Safari/Mac) preferences, but that didn’t change anything, not sure if that’s what you meant by ‘add a security exception to your web browser to ignore the ssl certificate’, I don’t see anything else in the Safari
What do you have in the ‘homeassistant’ section of your configuration.yaml file? Make sure it has the entry for - type: homeassistant so you can at least log in with a username and password.
Ah, thanks. I just realized that was also commented out (I had a similar problem months ago where I couldn’t log in and had commented that out to fix it). I must not have entered the network properly.
Forgive my naiveté, if my home assistant is on 192.168.123.456, (and I’m accessing it from 192.168.123.XXX), then what should I have for trusted networks? Ive seen some in the docs that have this:
would be correct. the /24 is the netmask. The first 24 bits (192.168.123) are for the network address and the remain are assigned to the subnet (.1-.254). A /24 network will be your typical home network with 254 assignable addresses
Excellent, thanks again. I’ll try that out in a little bit.
At some point I’m going to have to setup a test server to run Home Assistant on so that I don’t have to worry about locking myself out while I’m trying to get something working.
Yes, this is a 2 year old Topic, im sure there are quite a few Newer Topics / Solutions, if you use the search function ( try to variate the search words, to narrow it down you your particular use-case /Issue )
