Tried to update home-assistant with docker but still previous version?
Im on version .87 trying to update to latest, after docker reboot im still on .87
For a Docker container, simply pull the latest one:
$ sudo docker pull homeassistant/home-assistant:latest
I did this and rebooted the docker container, but still on .87
You have to stop and remove the old image before starting the new one
If you’re using hassio why aren’t you using the built in updater?
honestly, hassio didn’t show up until now…
why does it show two home-assistants?
Huh?
It’s only got one
What is the difference between homeassistant/qemux86-64-homeassistant and the hassio-supervisor?
Hassio supervisor is the orchestration container that actually provides you with the hassio menu, add-ons, and options. It’s what handles the updates and the container orchestration
