is it possible to call HASS from outside (like from a web browser) using a REST call (supplying a token with the call?) to perform an action/run automation?
There are two ways to call into HA using HTTP:
- Using a webhook. You need to POST to [Your HA Instance]/api/webhook/[WebHookID], and set up a trigger for an automation to run. This way doesn’t use HA’s security, and simply requires a hard-to-guess webhook ID. HA uses two concatenated GUIDs (with no hyphens) by default for integrations.
- Using the REST API, but that means you need to alter the request’s headers to include a (login or long-lived) access token.
Neither are particularly nice to have to do with a browser. I don’t think there’s a way to just use a GET request.
sounds interesting. in general i don’t intend to use a browser, but there are calls i wish to do from Tasker (android) which is currently using another https server i’m using. i’ll check that out - using web hook sounds like a good choice - 2 guids key is secured enough under https.
anyway if it’s possible to use POST instead of get and delegate the calls to GET, there won’t be an issue.
