drtanzil
(Drtanzil)
May 3, 2024, 10:32pm
1
I have created a helper input_datetime.fajr_time and set the time 5:10 AM
Now i want to trigger an automation 5 mins earlier at 5:05 AM.
How to run the automation bellow, 5 min earlier based on input_datetime.fajr_time?
alias: AA Fajr
description: ""
- platform: time
at: input_datetime.fajr_time
condition: []
- type: turn_off
device_id: f2500bf16b7e9e12c0aafc77049e7663
entity_id: 50ce6336052e0a28b9458b4af1a02a44
domain: light
mode: single
you can’t use the datetime as the trigger. you will need to use a template trigger:
lias: AA Fajr
description: ""
value_template: "{{ as_timestamp(states('input_datetime.fajr_time')) - 300 }}"
condition: []
- type: turn_off
domain: light
mode: single
drtanzil
(Drtanzil)
May 3, 2024, 11:54pm
3
@finity : I have added your code. But still its not triggering. Any suggestions?
You need to compare it to the current time.
If your helper is date-and-time use either:
{{ now().timestamp() >= as_timestamp(states('input_datetime.fajr_time')) - 300 }}
or
{{ now() >= states('input_datetime.fajr_time')|as_datetime|as_local - timedelta(minutes=5) }}
If it is time-only:
{{ now() >= today_at(states('input_datetime.fajr_time')) - timedelta(minutes=5) }}
weell shoot. of course you’re right. I guess I was distracted and forgot about that part.
thanks for the correction.
MAN!!!
@Didgeridrew
I’ve spent more than 2 hours or who knows how many posts using who knows how many failed templates trying to make this damn trigger work. And I finally found this solution and it worked flawlessly. I never had set up one of those buy me a coffee logins… until now… but I guess your next is on me. Thanks bro!
