Hi everybody,
I am currently writing an automation to use grocy.consume_product_from_stock
when a physical (zigbee2mqtt
) button is pressed.
This action is supposed to happen each and every time the button is pressed.
However, I would also like to use notify.alexa_media
if certain conditions are met. Is this possible without using templates?
Example
- alias: "Button Aqara Küche Mate Plus 1"
- platform: state
entity_id: sensor.button_aqara_kueche_kuehlschrank_action
to: button_4_single
# this ALWAYS happens
- service: grocy.add_product_to_stock
product_id: 3
amount: 1
# THEN a condition AFTER the first action...
condition:
condition: numeric_state
entity_id: input_number.helper_mate_kuehlschrank
below: 3
# ...and an action that only fires if the condition above is met
- service: notify.alexa_media
target: media_player.ben
message: "You will die soon if you don't buy more Mate!"
type: tts
There are two workarounds I can think off:
use a complex template that checks the condition first, then triggers the actions accordingly
create two separate automations =>
2.1. One to only firegrocy.add_product_to_stock
(each time the button is pressed) and
2.2. One to only check the condition and, if it is met, firenotify.alexa_media
While both these options should work fine, I’d prefer the example yaml I posted above, if this is somehow possible (or, perhaps, planned for future releases of Home Assistant??).
Thank you for your ideas
