The problem
I wanted a specific Unifi Protect AI alert (person loitering) to automatically pop up the camera feed on my Apple TV 4K. The catch:
- My cameras are G6 Turrets ā not doorbell cameras, so no doorbell entity in HA
- Apple TV only auto-pops camera feeds for doorbell accessories in HomeKit, not plain cameras
- The loitering alert is only available via webhook from Unifi, not as a native HA device trigger
- I didn't want general motion to trigger the popup, only the specific loitering alert
The Solution
Two blocks in configuration.yaml ā no automation needed.
Configure Webhook in HA to Use in Unifi Alarm Manager and the Template
1..Webhook-triggered template binary sensor*
This listens directly for the Unifi webhook and turns on for 5 seconds, acting as the virtual doorbell press:
template:
- trigger:
- trigger: webhook
webhook_id: "YOUR_WEBHOOK_ID"
binary_sensor:
- name: "Front Door Loitering"
unique_id: front_door_loitering
device_class: occupancy
auto_off:
seconds: 5
state: "true"
Replace YOUR_WEBHOOK_ID with whatever ID you want. Your Unifi webhook URL becomes: http://YOUR_HA_IP:8123/api/webhook/YOUR_WEBHOOK_ID
2. Expose the camera as a HomeKit doorbell accessory
This creates a separate HomeKit accessory (paired independently) that presents the camera as a doorbell device type, with a template binary sensor as the virtual doorbell button:
homekit:
- name: Front Door Doorbell
port: 21067
mode: accessory
filter:
include_entities:
- camera.your_camera_entity
entity_config:
camera.your_camera_entity:
linked_doorbell_sensor: binary_sensor.front_door_loitering
support_audio: true
Note:
mode: accessoryis required for a single camera doorbell. Make sure the port doesn't conflict with your other HomeKit bridges.
How it works
- Unifi Protect Alarm Manger fires the loitering webhook
- Template binary sensor turns
onimmediately - HomeKit Bridge sees the linked doorbell sensor trigger
- Apple TV pops the camera feed
- Binary sensor auto turns
offafter 5 seconds, ready for next alert
