Trigger automation 15 minutes before date_time stored in input_datetime
Just for fun, paste this into the Template Editor:
{% set t = as_datetime('1970-01-01T08:45').astimezone()%}
{{ t }}
{{ t.timestamp() }}
{{ now().fromtimestamp(t.timestamp(), now().tzinfo) }}
There’s a potential hitch with the idea of storing the time (for a time-only input_datetime) on the day of the Unix Epoch plus one’s timezone. The hitch is DST.
The result of the three templates is this (for my timezone):
1970-01-01 08:45:00-05:00
49500.0
  • The first line represents the 08:45 as a datetime object whose date is the Unix Epoch and whose timezone is set to the local timezone. It looks good.
  • The second line is the same datetime object but converted to a unix timestamp.
  • The third line creates a datetime object from the timestamp and the result matches the original datetime object. It looks good.
Everything looks perfect except the timezone offset now, in July August, is -04:00 and not -05:00 (which is OK for January).
This poses a challenge of how to use this arrangement to set a fixed time of 08:45 (for year round use) without it being offset by DST.
I’m beginning to see why it currently works the way it does … (namely as just the number of seconds since midnight).
Yeah, no-go.
What about
My as_datetime() and `as_timestamp() don’t appear to have the same magic as yours do.
What I showed is a proposal for a change that I implemented :slight_smile:
Indeed, currently, neither as_datetime nor as_timestamp work for a time-only input_datetime
Ah! My mistake; I didn’t understand that and thought you were demonstrating existing functionality.
I like it. It would make using a time-only input_datetime as neat as what petro proposed with a today() function:
{{ now() >= as_datetime(states('input_datetime.xyz')) - timedelta(minutes=15) }}
That happens to be the same template one can currently use if the input_datetime has both time and date.
Are you planning to create a PR?
Sure. Would be nice to get the feedback from @petro, as he already thought quite a bit about the problem.
What exactly did you change? Can you plop your changeset or branch?
Here you are
I don’t think that will pass a review. I could be wrong on that, but i would expect the changes to go in home-assistant/dt.py at 9fc92ab04e0d1933cc23e89b4095714aee725f8b · koying/home-assistant · GitHub
I want to post a detailed response but I’m on a crunch at work. I’ll have to respond in a day or 2.
What are your thoughts on making as_datetime convert a date-only input_datetime?
For example it would convert 2021-08-20 to a datetime object with the same date but at time 00:00:00 and one’s local timezone?
Basically, it would support conversion of all flavors of input_datetime to a usable datetime object.
That’s already the case, isn’t it?
Almost, the result is offset-naive (no timezone) so you can’t use it in a comparison with an offset-aware datetime object like what’s produced by now() or in date math.
Per ISO, no TZ means local time.
If I do
{{ as_timestamp(as_datetime(states('input_datetime.date_only'))) }}
I get a timestamp of 00:00 in my local time.
Home Assistant’s Jinja2 interpreter doesn’t appear to make assumptions when timezone is missing.
EDIT
FWIW, explicitly setting the timezone makes it offset-aware and then the comparison can be performed:
(Not so) fun fact:
If the timezone is not explicit, it’s the TZ of the machine (or container) that is picked up, via python I guess.
The vscode dev container is in UTC, even though the machine is in UTC+2, and I get timestamps in UTC. The TZ setting of HA is ignored, then, but now() still returns a datetime with the HA TZ :crazy_face:
Can someone help me with something similar like this?
I have a few time sensors and i want to make sensor which is - 15 minutes of the sensor.
So if it is 15.15 then i want the second sensor 15.00 and then i can trigger them for automations.
Any idea?
I have tried those things above but i cant program and just edited but with no luck sadly…
Post what you have tried but failed to work.
I have tried many things but like i said im a noob in this.
Just have this as last which isnt working ofc.
{{ state_attr(‘sensor.s_time’, ‘timestamp’) - 900 }}
{{ states(‘sensor.s_time’, ‘timestamp’) - 900 }}
{{ states(‘sensor.s_time’) - 900 }}
What is sensor.s_time? Is it produced by an integration?
Post a screenshot of how that sensor appears in Developer Tools > States.
You mean this?
Edit:
I have made this sensor from another sensor which had date and time.
