I am writing an automation that will trigger if an attribute of a state changes. I can trigger the automation if the attribute is one word - i.e. “Charles”, but when the attribute contains two words seperated by a space- i.e. “Charles Smith” it will not trigger. Can I change some how to make the automation trigger when the attribute contains a space? I tried “Charles Smith” and ‘Charles Smith’ - but it did not work
Show your automation code, please.
Code is below
alias: test
description: ''
- platform: state
entity_id: lock.maindoor
attribute: changed_by
to: Charles Smith
condition: []
- scene: scene.tand_huset
- service: spotcast.start
uri: spotify:playlist:146XtgzZNuYEVZdvpAh7O1
random_song: true
shuffle: true
start_volume: 20
device_name: Love
mode: single
Get “Charles Smith” to change the lock and look in Developer Tools / States. What is the actual value of the changed_by attribute?
It is Charles Smith in Developer tools.
However, if I change the trigger in the automation to Charles I can fire the rule from the Developer Tools by using “changed_by: Charles”; But if I change the automtion trigger to Charles Smith I can not fire the rule in Developer Tools by using “changed_by: Charles Smith”
What does the template tool say?
{{ state_attr('lock.maindoor', 'changed_by') }}
{{ state_attr('lock.maindoor', 'changed_by') == "Charles Smith" }}
{{ state_attr('lock.maindoor', 'changed_by')[0:7] == "Charles" }}
{{ state_attr('lock.maindoor', 'changed_by')[9:13] }}
{{ state_attr('lock.maindoor', 'changed_by')[9:13] == "Smith" }}
{{ state_attr('lock.maindoor', 'changed_by')[0:13] == "Charles Smith" }}
This should probably give us some clues what is gong on.
