Trigger automation from transaction log
Sorry probably a very silly question. I would like to trigger an automation each time the following message is received in the log. Is there anyway to do this? This message is from a SIP doorbell. The API does not let me read the button press, it seems to only let me change settings.
[zeroconf] Received from '192.168.1.20':5353 (socket 14): <DNSIncoming:{id=0, flags=33792, n_q=0, n_ans=1, n_auth=0, n_add=3, questions=[], answers=[record[ptr,in,_rtsp._tcp.local.]=4500/4499,Grandstream GDS3710 - 000B82B9A990._rtsp._tcp.local., record[a,in-unique,Grandstream-000B82B9A990.local.]=4500/4499,192.168.1.20, record[srv,in-unique,Grandstream GDS3710 - 000B82B9A990._rtsp._tcp.local.]=4500/4499,Grandstream-000B82B9A990.local.:554, record[txt,in-unique,Grandstream GDS3710 - 000B82B9A990._rtsp._tcp.local.]=4500/4499,b'\x06path=/']}> (178 bytes) as [b'\x00\x00\x84\x00\x00\x00\x00\x01\x00\x00\x00\x03\x05_rtsp\x04_tcp\x05local\x00\x00\x0c\x00\x01\x00\x00\x11\x94\x005"Grandstream GDS3710 - 000B82B9A990\x05_rtsp\x04_tcp\x05local\x00\x18Grandstream-000B82B9A990\x05local\x00\x00\x01\x80\x01\x00\x00\x11\x94\x00\x04\xc0\xa8\x01\x14\xc0(\x00!\x80\x01\x00\x00\x11\x94\x00\x08\x00\x00\x00\x00\x02*\xc0]\xc0(\x00\x10\x80\x01\x00\x00\x11\x94\x00\x07\x06path=/']
