I want to make an automation to apply time of day based brightness and color to smart lights ASAP after ANY smart light is turned on by a dumb switch and connects to HA. My goal is to avoid bright lights at night, and dim lights during the day.
To make this work I need a trigger that has two properties I’m not sure can be done:
a trigger that activates when a light connects to HA (e.g., after being offline due to dumb switch being off).
a trigger that activates when ANY light changes (i.e., no specific entity or device is specified, instead trigger is based on device category, in this case ‘light’).
Any ideas how to create a automation trigger with these properties? If this can’t be achieved with triggers, is it possible with an integration (which would presumably have access to the lower level HA event stream)?
Nice! I hadn’t thought of transitioning from ‘unavailable’ as connecting, but now it seems obvious.
Not sure what you mean. I’m looking for a trigger that is basically like you have in 1, except it doesn’t require specifying an entity_id or device_id, and instead monitors all lights that Home Assistant knows of. I wish there was something like a category: lights trigger so I could do:
- platform: state
category: lights
which would create an automation instance variable trigger.entity_id to indicate the specific light that triggered the automation.
I think a low-level event trigger like this might work to intercept all lights that re-connect to Home Assistant, but I suspect it would not be very efficient since it would check template conditions on every event HA processes, not just those for lights:
Edit: While the documentation of state objects mentions a domain field, when I observed state change events none had domain so the documentation is likely out of date. A hacky check on the entity_id string to determine domain should work, edited above code.
That should not really be a problem, but your ASAP requirement indicates you want it fast and that will not be the case.
The light will probably turn on when it gets powered again, but it can take several second and even over a minute for it to register in HA, because it has to boot and then reconnect to the network, then reconnect to HA, then update the HA entity.
Smart lights are not meant to be powered off, so try looking into smart buttons instead.
This is a fair point, ASAP != instant which isn’t ideal, but availability usually takes only a few seconds for my Matter bulbs which is good enough for now. My lighting auto-adjust is set to 1min 30sec intervals, which is roughly the current upper limit of adjustment time, so I’d be happy with say a 5 second auto-adjustment.
I agree using smart switches / buttons is probably the optimal solution in terms of speed and automation, but I want lighting to be controllable even if HA is down so dumb switches probably aren’t going anywhere. I’ve seen smart switches with dumb fallbacks, but they are pretty pricey and have more complicated wiring schemes. If a more affordable option with dumb fallback becomes available I’d probably go that route, but I would still want lighting to be auto-adjusted ASAP in the situation when the dumb switch is turned on.
