Trigger Automation once a day / every X hours
I have a Rainmeter/gauge to track how much water comes down. It will get triggered every 0.3mm of rain, so when there is a pour it’s quite often fired.
The first time the Rainmeter detects rain, it should give me a notification. But after that ignore for at least 5 hours.
I found a solution that goes with a condition template:
condition: template
value_template: >-
  ‘{{ as_timestamp(now()) -
  as_timestamp(states.automation.regenautomatik.attributes.last_triggered) | int
  > 1800 }}’
enabled: true
When I enter the code between ‘’ under Developer tools it works depending on the time.
But when I create my automation like this
it never becomes true, hence automation never fires.
What did I do wrong?
As I cant see your full template I can only comment on the one posed in text. There are a couple of things wrong with this template:
value_template: >-
  > 1800 }}’
  1. It is surrounded by quotes. Do not quote multi-line templates.
  2. Even if it was a single line template (which should be enclosed in quotes) they are the wrong sort of quotes. Use ' ' or " " not ‘ ’.
Edit: also 5 hours is 18000 seconds. Not 1800.
I tried to remove the quotes completely and it works. Thank you
