I’m looking for a way to trigger automation when an Insteon switch is turned on/off but only when it’s done so physically/locally, at the switch.
Can anyone help?
Thanks!
-Mike
Can anyone help?
Thanks!
-Mike
Include these conditions in your automation:
conditions:
- condition: template
value_template: '{{ trigger.to_state.context.id != none }}'
value_template: '{{ trigger.to_state.context.parent_id == none }}'
value_template: '{{ trigger.to_state.context.user_id == none }}'
Awesome, I’ll try it tonight. Thank you!
I believe Insteon switches report their physical activity (press/release button) as events. If so, you can use an Event Trigger to detect the events (i.e. detect when someone operates the physical device).
No luck. It won’t let me include conditions: plural. Says “Message malformed: extra keys not allowed @ data[‘conditions’]”. If I change it to condition: like this, it accepts it but the action doesn’t happen. Maybe I’m using the wrong trigger?
alias: Garage Light On by Switch
description: ""
- platform: device
type: turned_on
device_id: 6256aaee88409f1e391f4977fa966ed4
entity_id: aaaa9f97c56a23874e3d8798d9223afc
domain: switch
condition:
value_template: "value_template: '{{ trigger.to_state.context.id != none }}'"
value_template: "value_template: '{{ trigger.to_state.context.parent_id == none }}'"
value_template: "value_template: '{{ trigger.to_state.context.user_id == none }}'"
data: {}
entity_id: input_boolean.garage_light_on_by_button
mode: single
You’re using the wrong conditions.
Compare what you created:
to what tom_l recommended:
conditions:
Doh, that was a dumb mistake. Ok, it’s working…Mostly. Usually the automation triggers immediately. Sometimes, randomly, it seems to miss the message. The light turns on locally but the automation doesn’t trigger. If I press on or off again, sometimes 2-3 times, it eventually triggers.
You may want to consider experimenting with what I had suggested and see if it behaves better.
Yeah, I’ll check that out too. Thanks.
No event seems to go to insteon.button_on when any Insteon switch is turned on/off. It looks like it might just be for Mini-Remotes.
