Trigger Automation when Scene is triggered
Home Assistant release (hass --version):
0.35
Python release (python3 --version):
3.4.2
Component/platform:
scene and automation
Description of problem:
When my sleep-scene is triggered, I want to also call an automation.
I do not think that currently is possible.
You can have Ă  script in the frontend, that also trigger the scene
This works:
scene:
  - name: Test
    entities:
      light.test:
        state: on
automation:
  - alias: 'Event trigger'
      platform: event
      event_type: call_service
      event_data:
        service_data:
          entity_id: [scene.test]
        domain: scene
        service: turn_on
      service: homeassistant.turn_on
      entity_id: script.telegram
        variables:
          message: 'Test scene was turned on!'
Works like a charm. Thanks a lot!
This is not working for me, and I don’t understand why. It seems like the automation is not triggered at all. This is my code in automations.yaml:
- alias: Spegnimento luci
    platform: event
    event_data:
      service_data:
        entity_id: scene.spengi_tutto
      domain: scene
      service: turn_on
    service: tts.google_say
    entity_id: media_player.altoparlante
      variables:
        message: "Le luci sono spente."
Any ideas?
Could it be your double quotes in the last line?
I tried also with single quotes and different actions, but it still doesn’t work, so the problem must be in the trigger.
Edit: I’ve updated to 0.38.1 and now everything is working fine. I’ve no idea why, but I’m happy with that :smiley:
I’m trying to create an automation that triggers on every scene activation without any luck. I tried using a syntax without the “entity_id” part but that doesn’t work (no errors in my logfile):
- alias: 'Scene Activated Notification'
    platform: event
    event_data:
      service_data:
      domain: scene
      service: turn_on
    service: tts.amazon_polly_say
    data_template:
      entity_id: media_player.home_group
      message: 'Scene Activated'
      cache: false
When I do enter an entity_id it works but I don’t want to create an automation for every scene I have.
Any help is appreciated.
Haven’t tried this at all but maybe if you put an asterisk for entity id maybe it could work?
Or
entity_id:
    - scene.scene1
    - scene.scene2
    - scene.scene3
Not as ideal, but better.
Unfortionately both do not work.
Also tried:
entity_id: scene.scene1, scene.scene2, scene.scene3
Ah sorry, was just guessing… Probably the only way is thru appdaemon then
No problem, thanks for trying to help out :smiley:
Create a input boolean called “scene_on”, add it “on” to all of your scenes, create your automation based off of its state going from off to on.
I wonder if it is the lack of brackets for the entity id? I just tried the method outlined by martinhjelmare to trigger an automation off of a scene and it worked great. If only I knew where these magic commands came from…
I know this is a super ancient thread, but on the off chance someone is still following.
This event trigger automation works for me only if I trigger a call_service event in the Developer Tools Event tab. If I trigger the scene itself, this does no work for me. I’m new enough to HA that I’m at a loss as to how to find out why this seems to have worked for everyone else but not me…
I have what I feel is a much easier solution to this, I created a text_input that updated when any scene changed, and displayed the most recently changed scene. I then created an automation trigger based on when that text_input changed from any value to any value by simply leaving the “from” and “to” boxes empty. It successfully calls the automation every time.
