I want to select the weekdays and times in the frontend, in order to automate my sprinklers. For testing purposes i am trying to switch on an off a light based on this schedule. The frontend looks like this:
This is the yaml code for it:
- type: vertical-stack
cards:
- type: entities
show_header_toggle: false
entities:
- entity: light.kuche_1
- entity: sensor.timer_1_start_time
icon: mdi:clock-start
- type: custom:fold-entity-row
padding: 0
group_config:
toggle: false
type: custom:slider-entity-row
head:
label: Uhrzeit
type: section
items:
- entity: input_number.timer_1_start_hour
- entity: input_number.timer_1_start_minutes
- entity: sensor.timer_1_finish_time
icon: mdi:clock-end
padding: 0
group_config:
toggle: false
head:
label: Uhrzeit
type: section
items:
- entity: input_number.timer_1_finish_hour
- entity: input_number.timer_1_finish_minutes
- type: horizontal-stack
cards:
- type: custom:button-card
entity: input_boolean.timer_1_mon
icon: mdi:checkbox-blank-circle
color: rgb(25, 155, 20)
state:
- value: 'off'
icon: mdi:checkbox-blank-circle-outline
color: rgb(61,61,61)
entity: input_boolean.timer_1_tue
state:
- value: 'off'
entity: input_boolean.timer_1_wed
state:
- value: 'off'
entity: input_boolean.timer_1_thu
state:
- value: 'off'
entity: input_boolean.timer_1_fri
state:
- value: 'off'
entity: input_boolean.timer_1_sat
state:
- value: 'off'
entity: input_boolean.timer_1_sun
state:
- value: 'off'
Here are my defined input number:
## START TIME
timer_1_start_hour:
icon: mdi:timer
#initial: 6
min: 0
max: 23
step: 1
timer_1_start_minutes:
icon: mdi:timer
#initial: 30
min: 0
max: 59
## FINISH TIME
timer_1_finish_hour:
icon: mdi:timer
#initial: 6
min: 0
max: 23
step: 1
timer_1_finish_minutes:
icon: mdi:timer
#initial: 30
min: 0
max: 59
step: 1
Here are my defined sensors:
## START TIME ###################################################################
sensors:
timer_1_start_time:
friendly_name: "Start Time"
value_template: >-
{{ "%0.02d:%0.02d" | format(states("input_number.timer_1_start_hour") | int, states("input_number.timer_1_start_minutes") | int) }}
## FINISH TIME #################################################################
sensors:
timer_1_finish_time:
friendly_name: "Finish Time"
value_template: >-
{{ "%0.02d:%0.02d" | format(states("input_number.timer_1_finish_hour") | int, states("input_number.timer_1_finish_minutes") | int) }}
This is the automation i have tried, however i cant get it to work, it just wont trigger:
- id: "1769202750885"
alias: Timer 1 Finish Time
description: ""
- platform: time
at: sensor.timer_1_finish_time
condition:
- condition: template
value_template: "{{ is_state('input_boolean.timer_1_' ~ ['mon','tue','wed','thu','fri','sat','sun'][now().weekday()], 'on') }}"
- service: light.turn_off
entity_id:
- light.kuche_1
data: {}
mode: single
The sensor state contains the right time, as can be seen in this picture:
i really dont know what could be the problem here, any help would be appreciated. Thank you!
