Trigger bases sensor to calculate difference between previous & current state
I’m trying to create a template sensor to calculate the difference between 2 states for an entity.
the entity itself just is an ever increasing value
I tried adding the template sensor below , but the sensor is allways unknown
`template:
  • trigger:
    • platform: state
      entity_id:
      • sensor.airco_keuken_energy
    • name: “Current Airco Keuken Power Current State”
      state: “{{ trigger.to_state.state - trigger.from_state.state | float | round(2)}}”
You are missing a float(0)… so your first state is a string
"{{ (trigger.to_state.state | float(0) - trigger.from_state.state | float(0) ) | round(2) }}"
state: "{{ (trigger.to_state.state | float(0) - trigger.from_state.state | float(0)) | round(2) }}"
I did that now, but the result keeps being ‘Unknown’ state
It will report unknown until sensor.airco_keuken_energy changes state.
After I changed the code to
state: "{{ (states('trigger.to_state') | float(0) - states('trigger.from_state') | float(0)) | round(2) }}"
I got something else then Unknown, but it still doesn’t update
That’s not the template I suggested to you. Compare what I posted above to what you have and you’ll see they’re not the same.
Hi, Yes, I had done that first, waited until there was an update of the base entity and it didn’t seem to work.
So then I changed the code to what I had above and it didn’t work either.
Now I changed it back to what you wrote and now it seems to work! Looks like it was another USB-moment for me… )
Next step I’m trying to achieve…
The from_state & to_state are 2 values in kWh.
It seems to be possible to also get the from_state.last_changed & to_state.last_changed
So from that I want to try and calculate the average W used in that period…
