I have set up a trigger binary sensor that i want to update when states change to any value for either of 2 helpers (input_text.front_bedroom_right_lamp_state or input_text.front_bedroom_left_lamp_state) or a third sensor changes to on (binary_sensor.template_ha_restarted_3minutes).
I have changed the value for the first of these.
The sensor is yet to be created so the trigger has not been fired.
I know the template code to set the state is fine as it is returning the correct on state in developer tools. Does anything look odd with this code?
- trigger:
- trigger: state
entity_id:
- input_text.front_bedroom_right_lamp_state
- trigger: state
entity_id:
- input_text.front_bedroom_left_lamp_state
- trigger: state
entity_id:
- binary_sensor.template_ha_restarted_3minutes
to: "on"
binary_sensor:
- name: front_bedroom_lamps_state
- state: >-
{% if is_state("input_text.front_bedroom_right_lamp_state", "LampTouch1") or
is_state("input_text.front_bedroom_right_lamp_state", "LampTouch2") or
is_state("input_text.front_bedroom_right_lamp_state", "LampTouch3") or
is_state("input_text.front_bedroom_right_lamp_state", "LampTouchRGB") or
is_state("input_text.front_bedroom_left_lamp_state", "LampTouch1") or
is_state("input_text.front_bedroom_left_lamp_state", "LampTouch2") or
is_state("input_text.front_bedroom_left_lamp_state", "LampTouch3") or
is_state("input_text.front_bedroom_left_lamp_state", "LampTouchRGB") or
states("input_text.front_bedroom_right_lamp_state") is match("[\x23]") or
states("input_text.front_bedroom_left_lamp_state") is match("[\x23]") -%}
on
{% else -%}
off
{% endif %}
