Considering the following event data (confirmed both by “listen events” and event trigger trace )
idx: '0'
alias: null
platform: event
event:
event_type: call_service
domain: select
service: select_option
service_data:
option: Chill
entity_id:
- select.winamp_radio
I am expecting the following automation to send the payload “Chill” to the “homeassistant/button/SS/winamp_radio/state” topic.
But the payload is empty. (MQTT explorer confirms by deleting the topic)
replacing “{{ trigger.event.data.option }}” with anything else like “test” for instance will go through.
alias: WINAMP radio select - reset option
description: ""
- platform: event
event_data:
domain: select
service_data:
entity_id:
condition: []
- service: mqtt.publish
topic: homeassistant/button/SS/winamp_radio/state
payload: "{{ trigger.event.data.option }}"
retain: false
enabled: true
mode: single
Any idea where the problem is? I’ve tried checking my syntax numerous times and searched the forum for clues but couldn’t come up with a solution.
Thank you!
