Hi everyone,
i seem to have a little issue with my automations and i can’t figure out why.
Short description:
I have a deconz gateway which is only responsible for 3rd party zigbee switches and sensors.
In my case they’re all from xiaomi.
Now i configured a bunch of automations for those xiaomi switches, but sometimes they simply don’t get initialized.
I’ve been able to break it down to a really strange behaviour.
My steps for reproducing:
- Config: https://pastebin.com/raw/ujLwU3dD
- Hass initialized automations correctly
3: Logs
Mar 10 16:59:30 hass hass[19673]: 2019-03-10 16:59:30 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Turn Kitchen Light on Xiaomi
Mar 10 16:59:30 hass hass[19673]: 2019-03-10 16:59:30 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Turn Kitchen Light off Xiaomi
- Apply initial_state like here: https://pastebin.com/raw/aRWTzMkB
- Only first automation will be loaded (initialized)
6:
Mar 10 17:03:41 hass hass[19857]: 2019-03-10 17:03:41 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Turn Kitchen Light on Xiaomi
7: revert to first config and restart
8: Only first automation will be loaded (still)
9:
Mar 10 17:04:41 hass hass[19903]: 2019-03-10 17:04:41 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Turn Kitchen Light on Xiaomi
10: Change names of automations by at least one character
11: Gets initialized correctly
12:
Mar 10 17:05:56 hass hass[19950]: 2019-03-10 17:05:56 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Turn Kitchen Light on Xiaomi Button 1
Mar 10 17:05:56 hass hass[19950]: 2019-03-10 17:05:56 INFO (MainThread) [homeassistant.components.automation] Initialized trigger Turn Kitchen Light off Xiaomi Button 2
If i’m setting “initial_state” for this now, only the first automation will be loaded until i change the name.
Changing the name if “initial_state” is present does not make a difference. Only one automation gets loaded.
Both automations only get loaded if don’t set initial_state and change the name if initial_state was configured for the automations name before.
My Goal was to just use one button for turning a group of lights on and off, which i thought shouldn’t be that hard.
I hope i described it clear enought to understand and would appreciate any help…
If more logs are needed please poke me for it and i will provide them.
Thanks in advance,
Kedakai.
EDIT:
Okay, i seem to have misinterpreted the “initial_state” variable quite a bit.
homeassistant.toggle as an action solved my issue.
However it is strange that the automation doesn’t get initialized after initial_state has been deconfigured and the name of the automation hasn’t changed. Seems more like a bug to me.
